Good Old-Timer mechanic for Carb/Vacuum issues (86 6cyl) in PA? - Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Old 03-25-2014, 04:54 AM
WalterRoad WalterRoad is offline
WalterRoad is starting off with a positive reputation.
Does anyone know of a good place to go for carb/vacuum issues in the central PA area (anywhere between Stroudsburg and Lewisburg or even close)? I'm actually from CT, but have family in PA so I'd be willing to travel to the PA area too...
Anybody know of someone who's familiar with the older factory setups, I'm as good as any to swap parts, I'm hoping to find someone who's good with these older vacuum and carb'd setups for some fine tuning. The van is my everyday/everything truck. Any pointers would be very much appreciated, thanks!
Old 05-23-2014, 02:48 PM
Gettysburg150's Avatar
Gettysburg150 Gettysburg150 is offline
Gettysburg150 is gaining momentum as a positive member of FTE.Gettysburg150 is gaining momentum as a positive member of FTE.
What kind of problems are you having?
Im no expert in the carb department, but I know ethanol fuel sucks (most everything around me is up to 10%) and vacuum lines like to crack and break.
Old 05-23-2014, 04:38 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
It's getting tough on some of this stuff. Once the current independent shops finally hang it up, forget it. You're on your own. The good thing is, the web sites that weren't around 20 or 40 years ago will teach you as much as you can handle about carb tuning or anything else. You need a tach and a vacuum gauge in addition to the usual tune up stuff.
Old 05-27-2014, 02:43 PM
quaddriver quaddriver is offline
quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.
well the first thing you can do it locate, photograph and post your VECI label (vehicle emissions control information) it lists every hose on that motor as installed for that cert, by the factory. Many a time I have used it to verify equipment, problems, restore 'expert' repairs.
as someone mentioned, parts are going to be hard to have...too many of these things have been smooshed and sent to china....
Are you having EGR or spark porting issues? (most common on the I6)
where is said label? Can be on the hood, air cleaner or radiator valence.
If you toss out a vin we might be able to work backwards and find a 'generic' one online.
Old 06-01-2014, 05:33 PM
GLR's Avatar
GLR GLR is online now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Where in NY are you located?
I'm an old-timer mechanic but, not saying I'm good.
Old 06-17-2014, 08:47 PM
amtrakjoe amtrakjoe is offline
amtrakjoe is starting off with a positive reputation.
Good Mechanic
Hello, If you're making your way to Pennsylvania you can make a turnpike stop at Bowen carbouretor. Look them up on the internet. They are in Bucks County Pennsylvania just north of Philadelphia. They are wonderful mechanics. Call ahead of time. - Joe
Old 06-30-2014, 07:55 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
86 is a feedback carb, check your engine codes first, you may have a sensor problem, not a carb problem.
Rerouted PCV & brake Booster Vacuum Lines, have questions Da_Lariat_Chariot 1987 - 1996 F150 & Larger F-Series Trucks 1 05-19-2016 02:34 PM
Slick in West Chester, PA svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 0 06-08-2015 03:46 PM
Looking for a good mechanic- South Western CT, will travel (Carb'd 86, vacuum, etc) WalterRoad Connecticut Chapter 1 08-01-2014 04:50 PM
Duraspark2/YF carb/vacuum difference 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 7 08-03-2011 02:32 PM
north east pa powerstroke specialist? jessejames88 1999 - 2003 7.3L Power Stroke Diesel 8 02-24-2006 03:03 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
