Performance info needed...
I was sitting around, and a thought came to me. On an '86 F-150, how much difference would it make to have a split manifold and 4 barrel carb? And then I realized, you people would know. How would these things affect gas mileage, speed, and general performance of said truck?
Thanks in advance,
Thanks in advance,
300 inline 6. Man I bought it from loved to tinker, and it works, supposedly. As in, it runs. Haven't had the time to really dig in to this new one. He just mounted the four barrel carb (incorrectly) and converted to a spit manifold. And I'm pretty new as a poster, but have pretty much always have lurked around here for tips, so once my first 10 days are up, I'll make sure to fix me a signature.
Ok, now that you've explained I'm sure someone will come along that knows. But, in the immortal words of Bob Dylan, It Ain't Me, Babe. I've not done that to a six.
But, I can talk in generalities. In spite of what the rags say, in my experience freeing up the exhaust does not help MPG. But, it sure does help RPM. Unfortunately the 300 isn't normally wound up much so I would not expect that allowing it to breathe on the top end would help dramatically. But, that is my interpolation based on my experience with V8's and may well be wrong.
As for MPG, that is helped by getting a good strong vacuum signal in the carb, and that is done mainly by the size of the throttle plates. (It is also helped by better designs of venturi, but that's another story.) And, a small 4bbl can have smaller throttle plates than a 1bbl since the 4bbl has the secondaries and not everything has to flow through the primaries. So, a small 4bbl can actually help MPG - as long as you stay out of the secondaries.
Thanks, but that's leads into the improperly mounted carb. He set it up where you're not getting two primaries, but one primary and one secondary. It'll just take a little time to fix, but I wish he would've saved me the time. He was more of a Renault man, I mean the only Renault man, in east TN.
Xeneum
05-11-2013 09:22 PM
1986F150six
07-25-2012 02:13 PM
evan.kelly978
04-07-2012 12:18 PM
gquinn8516
31
03-24-2008 09:23 AM
