02 Excursion TV Replacement
#76
So the fancy wire job shown above - will I encounter the same thing in my 03?
I have the same DVD setup size/shape - just need the IR unit to wire up.
Will the plug be the same once I drop it...
Not sure what unit came in the 02...seems like a lot wire changes just to add IR headphones.
#77
Just to get this right, You had the DVD without the IR, and swapped in this unit with IR.
My current DVD has the grey square plug that plugs into my current DVD....and the IR units have the rectangle plug - which you researched and found the harness you needed to make it plug in so nice.
I guess I am asking, my setup will go similar if not exact to what you did?
#78
#79
armstrong001
04-03-2019 06:26 AM
