91 f150 column trouble
My old.column went out . So i bought a used one ,feels a little wore but not bad. Ignition is really sticky. Anyway i just installed the column checked all wires. Everything is hooked up. But i cant get power to the column, or the cab. Does a bad Ignitioncolumn cause this? No blinker no fuel pump nothing . Im going to be irritated if i got took for a column.
I ran into the same issue with my 89 once in 90 they switched wiring harnesses so something's could be different. My truck was a 89 with a I6 and I swapped in a 91 351 column and it wasn't right. No cruise, horn, or ignition. Swapped one in from a 88 with a 302 and it ran fine... Just my two cents hope it helps
Bruners4
02-09-2015 11:53 PM
dcberg
02-26-2010 07:31 PM
