Larger tires affecting speedometer
What also might help is you can take a video of what you're doing and post to YouTube so we can see if you're missing a step or something.
How can you rebuild a PSOM other than change the caps?
I would like to see what math they used to do that.
Making sure things don't fall off is a good start, this was my issue back a few years ago...
https://www.ford-trucks.com/forums/7...ml#post6657625
No idea, you would need to ask them. I do remember on the site I found (years ago) that if I had to buy a new PSOM where I told them what mileage to program, they required a document to be signed stating that was the true mileage of the vehicle.
Just wanted to update this thread. I went out to try one more time to recalibrate the speedometer. I tried grounding the PSOM to several points around the cab that I felt sure would give a good ground, no luck any time. Finally I stuck the wire behind a screw that is holding the door panel on, a last resort before giving up really. Well, it worked!
Thanks to all who helped, and provided the link to reprogramming.
joegeds
10-10-2013 09:13 AM
andyj ford driver
05-28-2010 12:50 PM
Lite
05-25-2010 02:32 PM
jleach
10-26-2000 03:19 PM
Joe
12-25-1999 03:56 PM
