POR-15 How Much To Buy???
That's less than half the price of a gallon of POR15 around here.
So you don't need the marine clean and very little metal prep is required, and you just dump it and spray it on? You don't have to thin it? What do you use for equipment cleanup afterwards? Just regular thinners and solvents? I'm really interested in this as an alternative. Is this what you used on the bottom of the cab on Swagger?
My mistake I remember now you said it was Herculiner or something similar. Don't make a special trip for this. I'm still a little ways off from being ready to do this project. If you don't mind asking them about it when you're there that's great, but don't feel like you need to make a special trip.
Ok guys I finally pulled the trigger on paint for the frame.
1 gallon Amercoat 370 in pearl gray (primer)... $53
1 quart of Amercoat 370 cure... $13
1 gallon Amercoat 450h in gloss black... $74
1 quart Amercoat 450h cure... $18
1 gallon Amercoat 101 thinner... $33
Got away at $200 which is what a gallon of POR is iirc
They make a product to add to it if brushing on ... i can get that number if anyone needs it
Hoping to spray Sunday and I'll get some pics up
