Shifter wont go in to transmission 81 f100 - Ford Truck Enthusiasts Forums
Old 03-22-2014, 11:53 PM
cook134 cook134 is offline
cook134 is starting off with a positive reputation.
Hi, I have a question about the transmission and shifter in my 1981 f100 2wd. The transmission is a RUG s-rod 3 sp with overdrive. I took the shifter out while the truck was in reverse and now I can't get it to go back in. I think that it has to be in neutral. Is there anyway to shift it without the shifter installed? Thanks
I need a picture of highboy stick shifters F350moneypit 1967 - 1972 F-100 & Larger F-Series Trucks 12 03-24-2017 09:17 PM
manual 4wd shifter pass1over 6.0L Power Stroke Diesel 8 05-07-2016 04:52 PM
Moving shifter to the floor svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-11-2014 07:41 AM
3-speed Shifter Linkage ratrod1923 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 06-30-2014 02:22 PM
4 spd shifter for 71-f100 hotrodfordpickup 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-16-2007 10:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
