How to: Modifying bottom rear mount for bullnose fender swap.
Old 03-22-2014, 09:32 PM
damarble's Avatar
damarble
damarble is offline
I've seen this asked a few times so here's a pic by pic walkthough to get your fender to bolt on if you swap a bullnose clip on.
What you start with:
Measure down about 3/4" to 1" depending how much margin of error you want for shimming and mark a line all around. Cut. A 4.5" angle grinder with cutoff wheel fit fine:
The bolt is going to come through right below that front piece so zip it off too:
Make a tab. I harvested mine from a junk bullnose cab I had but it's simple enough to make from scratch too:
Space the center of the hole out 2.25" from the back and weld it on, slip a clip nut over the hole and you're ready to mount your fender:
Old 04-26-2014, 06:47 PM
dazedandconfused's Avatar
dazedandconfused
dazedandconfused is offline
I just cut mine off of my old cab
Old 04-28-2014, 04:52 AM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
This should be a sticky
Old 04-07-2016, 08:51 AM
damarble's Avatar
damarble
damarble is offline
2 years later and it's still working well.
Johnny Carnes
03-07-2020 11:08 AM
btred1466
Ford Truck Parts for Sale
02-07-2018 12:27 PM
Wmrdalydvm
22
01-07-2017 06:46 AM
jrockdiddy
12-09-2015 09:40 AM
jrockdiddy
16
10-30-2013 03:14 PM
Quick Reply: How to: Modifying bottom rear mount for bullnose fender swap.
