A.C. compressor mounting
Old 03-22-2014, 09:11 PM
John R. Thomas's Avatar
John R. Thomas
John R. Thomas is offline
Ref. our 75 F-150 with a 390.
Question: Is the A.C. compressor mounted standing up or on it's side?
If on it's side, the tubular brace connects to…?
Old 03-22-2014, 09:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Here's my '75. The brace goes from the compressor to the exhaust manifold.
Old 03-23-2014, 02:51 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
79 Bronco 351M C-6 trans, compressor mounts on its side. No brace.
Old 03-23-2014, 03:38 AM
77&79F250's Avatar
77&79F250
That's great advice for the guy....or was that an attempt to be funny?
If so that was a FAIL.
I guess we should just agree to disagree, on everything.......and let it be.
Old 03-23-2014, 05:38 AM
EricJ's Avatar
EricJ
EricJ is offline
If you are using stock AC hoses, I'm guessing they will only work with the compressor mounted correctly. The suction line probably wouldn't care, but the discharge line to the condenser probably wont reach if it's mounted wrong.
If you're having the hoses made, or the stock ones actually reach, it wont matter how you mount it.
Old 03-23-2014, 08:40 AM
John R. Thomas
All 4 of our vehicles have ac. My wife has had hot flashes since 09. She won't ride
with me without ac. We are in the Milwaukee area. 2012 was a hot year.
Original question: My compressor is vertical. Is that correct? Should I attempt to
remount it horizontal ? (without breaking a seal)
Old 03-23-2014, 08:49 AM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
You should be able to mount it horizontal if you want. The lines should rotate with no issues.
Old 03-23-2014, 09:52 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Original question: My compressor is vertical. Is that correct? Should I attempt to remount it horizontal ? (without breaking a seal)
From the factory the compressor was mounted in the vertical position.
Old 03-23-2014, 01:16 PM
John R. Thomas
Thank You. Next problem is loosening a header bolt for the tubular brace.
I have a brace to reach the 1st or 2nd bolt. However, even with lots of soaking with
various sprays and even a hand torch, neither one will brake loose.
Any sure fire solutions?
Old 03-23-2014, 01:50 PM
77&79F250's Avatar
77&79F250
Have you tried "freeze off" or any other cold break free trick?
- Henkel North America
http://www.crankshaftcoalition.com/w...tuck_fasteners
PB blaster, Kroil, mouse milk.... Welcome to MouseMilk.com
10 Tricks to remove that Stuck, Seized, or Stripped Bolt/Nut | Eastwood Blog
CRC Freeze-Off Super Penetrant
You do not want to break either one, they are a major PITA with the steering shaft, shock tower and maybe a 1/2 coil spring bucket in the way, if you have it drill out.
Drill bits and easy outs brake too....ask me how I know....
Bad day goes worse there is always a "helicoil". If you can get the busted piece out and get it some what drilled.
I have better luck with a cold versus hot removal.
ManfredVonRichtofen
WTB - Parts & other
01-01-2016 11:45 PM
jake22si
1997 - 2003 F150
06-28-2015 09:04 AM
wheelie31
06-20-2010 10:36 PM
Psycho Sasquatch
08-31-2007 11:55 AM
Quick Reply: A.C. compressor mounting
