Lifter Pump leaking oil - Ford Truck Enthusiasts Forums
Old 03-22-2014, 07:56 AM
10thMountainMechanic's Avatar
10thMountainMechanic 10thMountainMechanic is offline
10thMountainMechanic is starting off with a positive reputation.
Hey guys need advice on a lifter pump. I was under my truck yesterday Looking to do a coolant flush and oil was all over the bottom of my engine. I took a look and the lifter pump was the source of the leak. I pulled the oil dipstick and It didn't smell like diesel so I'm thinking it might just be a bad seal on the lifter? It's leaking quite a bit but I don't have much time or money to fix it...Is it gonna be a big problem if i leave it alone for awhile or am I in trouble of fuel gettin in the crankcase? If i pull the lifter is it better to just replace it or reseal it? How much does a new lifter cost and how hard is it to replace?
Old 03-22-2014, 08:41 AM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
There is a gasket that seals the lift pump to the engine. Your gasket is either missing or leaking. Its only a few dollars for a new gasket, or you might be able to just use RTV.
Fuel leaking in happens when the diaphragm in the lift pump fails. Two totally different and unrelated issues.
Pretty easy to pull it and reseal. No reason to replace it
Old 03-22-2014, 09:15 AM
sweet thats some good news thanks!
Lifters. Suggestions anyone? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 02-17-2016 10:04 PM
Flat tappet lifter replacement timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 3 10-16-2014 11:57 PM
Cleaning Intake Valley and Lifters? Ripcity 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-16-2013 01:24 PM
Lifter Question 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-25-2012 08:57 PM
serious oil pressure issue!!! please help me eric77crew 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-02-2012 04:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
