Uh oh.....
Uh oh.....
We bought the sons truck non-running and knew we were taking our chances. No biggie deal, I wasn't scared!
The PO had mentioned that when he stopped driving it that it had a lifter tick.
After pulling the valve cover, we got a little surprise. I think his lifter tick was more like a miss.
Only on push rod is bent and only three pedestals are raised.
My question is, how do you push them back down?
That sort of abuse/neglect tells me two things: you need to pull the head and have the studs pulled and bosses tapped for ARP sbc studs. I think it will run $50 for the machine shop to do it. Install the new studs with loc tite. They go into the coolant. Secondly, that sort of neglect shouts that the rest of the head needs to be checked. Are the springs properly installed? Do they have the required psi? How old are the locks, the retainers, springs? How do the valve guides look, the seals? I would definately go through it. In my experience it is always better to address an issue before it breaks and causes a break down.Good luck.
Xwarrior86
21
04-07-2017 08:22 PM
Carloespo
63
05-12-2016 06:29 AM
85 xlt lariat
24
10-17-2012 08:53 PM
