1965 F100 Flareside Spare Tire Bracket & Fender
Good luck on your quest's if you's find a hidden batch of them let me know. https://www.ford-trucks.com/forums/1...ire-mount.html
YANANANANANANANANANANANNA
Removed the 'cut' fender on the 65 due to serious rust which I kept, when time permits intend taking to auto body shop for estimate. Meantime, salvaged a standard replacement fender and tire rack and installed the tire under the bed. I have been looking for the fender w/ the indent for past couple years and have not been successful.
Have you thought about trying to graft the indent from your original wheel flare into a reproduction flare? Just a thought if your original is to far rusted may be easier to do it that way. I been looking for years to for one to put on my 64 still no luck on my end.
I did consider that however, came across a fender at swapmeet where seller had taken the standard fender and fabricated the indent and just did not look all that great, of course depends on persons workmanship. Actually, I just need to get off by backside because I believe it would be less labor intensive if I have the original repaired, there's cancer along the edge where the fender attaches to the step,other than that the fender is in fair condition?
The mount is bout as hard to find as hen's teeth, have not seen but a couple on ebay over past 20 years. There's a 68 mount on ebay, looks similar to my 65, wonder if it would work with a little refab??
Originally Posted by vntgtrk
IIRC Flareside beds are the same '57 to '73 so the likelihood is it will bolt right up.
Applications: 1957/79 F100 & 1975/79 F150.
B7C-16313-B .. Left Rear Fender with cut-out for spare tire / Use with 6 1/2' Flareside beds / Obsolete
B7D-16313-A .. Left Rear Fender with cut-out for spare tire / Use with 8' Flareside beds / Obsolete
1957/79 F100/250 & 1975/79 F150.
Pic from 1964/72 catalog:
