Weatherstripping
Weatherstripping
Any tips on installing the weatherstripping that goes between the door and the cab?
What is the best adhesive?
And should I start at the bottom or the top, and does the rubber go on the actual door itself or around the door on the cab where the door closes?
I know these might be dumb questions, but "Oh well.."
Any advice would be MUCH appreciated...
Hey Bro. I have not done mine yet but when I do I'm going to use two adhesives. One being the 3M yellow weatherstrip adhesive. AKA gorilla snot,yellow glue of death. And also #77 spray contact adhesive. Mount them with a small bead of the yellow stuff. This will be used as the permanent adhesive. The #77 adhesive I will use to hold the weatherstrips in place while the yellow glue is drying. IMHO I would start on the bottom in the middle. Go around and end there. Better chance for no wind noise or leaks sneaking through.
Mearntain
15
09-13-2020 08:40 AM
jhaas63
07-10-2013 06:07 PM
