1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
NON-tapered blocks right?
Old 03-21-2014, 02:39 AM
NTENSE's Avatar
NTENSE
NTENSE is offline
2003 F250 crew cab, short bed, 4x4. from what i've read here my wheelbase is 156" and i will need NON-tapered blocks. replacing 2" blocks with 4".
Old 03-21-2014, 09:39 AM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
Yes Flat-Blocks is what was required on my 2006 F250
The kit I installed (Pro-Comp # 62667K) came with Tappered-Blocks which put a big pinch in my Driveshaft @ the Pinion & a vibration
Lets say ProComp was adamant i needed Tappered but I was even more persuasive about the Flat-Blocks (sent them the following pic's) & they agreed to send me Flat-Blocks free of charge....
Now she's perfect
*Pics to follow
Old 03-21-2014, 09:42 AM
King-bRanch
Here's some Pic's showing the difference, after this most other people on here seem to have Flat-Blocks also so I say u need Flat's.....
Hope this helps
Old 03-21-2014, 05:28 PM
NTENSE's Avatar
NTENSE
NTENSE is offline
Wow!!! It doesn't get any clearer than that! Thank you very much.
Old 03-23-2014, 06:10 AM
spud57's Avatar
spud57
spud57 is offline
King-bRanch, have you experienced any vibrations or shutter since adding the blocks?
Looking at Fords TSB to add the blocks, they replace the carrier bearing and even the drive the drive shaft in some cases.
SD-Dude
04-18-2011 06:44 PM
Kennewick
18
09-02-2010 03:16 PM
2006HarleyF250
26
01-26-2006 01:47 PM
I_Thnk_Ford
03-16-2003 11:39 AM
blaxuede
05-13-2002 12:58 AM
Quick Reply: NON-tapered blocks right?
