Kill switch on a 80-86 Bullnose??
I know killing the fuel pump will do the same thing, but if you don't have an electric pump just install an early style fuel tank switching valve. They are electrically controlled but don't pull power except when actually changing from one tank to the other. Here are several scenarios:
- If you had dual tanks but don't use both, just seal off the line from the tank you aren't using and flip the switch on the dash to that tank when you want to prevent it from being driven.
- Ditto above but use an alarm system to treat the valve as a door lock and turn the valve to the non-existent tank with the alarm on. Automagically it will go back to the existing tank when you unlock.
- If you still use both tanks you can still add another valve, just install it between the existing valve and the engine, and cap one inlet off. And put a hidden switch somewhere to control it.
I like the idea of having it at the bottom of the door, but A. I don't know how i'll keep water or moisture away from it and all the wires without ruining it, and B. there will be a fair amount of wires in the door already and IF someone was watching me hop out of the truck, they would see me flip the switch. So that leaves me with mounting it under the seat.
I think something like that eBay switch is a little too big and noticeable. I was thinking something along these lines:
Under the door is BRILLIANT!! I'm only worried about water getting in the door and then shorting it out, then i'm f'd. Also, i'm worried about it rubbing, but i'd have to do some measuring first.
Otherwise, i'm thinking about somewhere under the dash where no one would ever think to look. Or maybe the inside of the sun visor. Ya know...something where no one would ever think to look.
You can also get creative with hidden proximity switches behind trim, the sky's the limit - good luck
Goto to post #50 here for the revenge!
https://www.ford-trucks.com/forums/1...l-trans-4.html
Oh man I love dogs. I think I would've kicked the S outta him just for the hell of it. I swear people have no common sense or decency, and S-heads like that need to be taught a very valuable lesson....like what life is like in a wheel-chair.
I haven't selected the hood lock yet, but I've installed them and they work well. Mine will be coupled with an alarm system that locks/unlocks the doors and hood, kills the ignition, and has various sensors to detect the doors or hood opening when the alarm is set - in which case it sets off an alarm. Nothing sophisticated, but a good basic system that provides security with convenience.
For an alarm system, swap the external siren ( nobody pays attention to them anyhow) for a high intensity piezo screamer inside the cab. Makes it very uncomfortable to hang around in there trying to complete the theft.
Good ole Florida summer time sun cooked him really good! As he did not roll down any windows the temps were OVER 130deg F!!!! I let him out due to I did not want to deal with a dead cooked crook on my hands in the car but had fun taunting him with the Rex and my dogs!
Ya know, he could've died and then you just pretend you got home late and not know anything about it. One less f'r off the planet.
I have installed Kill switches on most of the vehicles I have owned . I sold one to my little brother years ago . After 3 days at a shop ( he lived over 100 miles away ) he called for advice . While on a date ,someone's foot found the kill switch ! The mechanic could not figure out why the coil was not firing ! I told them where the switch was located . Easy to get at , hard to find ..... I run a bit of wiring ,looks factory , and isolate the coil . I know it works ! Around the e brake area on my 78 with a small push pull switch .
#29
