96 f350 fuel canister empty, tanks full
Tried to start truck without success. Charged batteries and checked fuel canister and it was empty. Filled fuel filter canister but still won't start. Why was the canister empty and how do I reprime the system? Started about 1 1/2 months ago and all seemed fine.
if so its not supposed to have fuel in there
what engine? if its a stroke I'm assuming you are referring to the fuel bowl
Sorry for not being more descriptive. The engine is a 7.3l diesel and I'm referring
to the place you put the fuel filter. I just call it the fuel canister. Any way I can't
figure out where the fuel went. I filled the canister and replaced the filter and tried
and tried to start the engine to no avail. I'll check again tomorrow and see if it drained
again. But then how do I get the darn thing primed with diesel?
Received 3,090 Likes
on
Check the easy things first, make sure you closed the the drain valve on the fuel filter housing and that the pumps are running correctly. After I change my filter I usually cycle the key 3-4 times waiting until the wait to start light turns off so the housing has ample time to fill with diesel. You could possibly have a leak on your drain valve, just look underneath the truck for any signs of diesel. I'm assuming you just changed the filter, that's where I coming from with this. If not you may want to check your fuses since your fuel pumps don't seem to be running.
bulletpruf
08-12-2012 01:31 PM
mickeyderry
12-16-2005 07:15 PM
