73-79 Ford truck or Bronco 6" lift, trussed and disc Ford 9, rebuilt d44
Category: Steering & Suspension
Price: $600
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude, S2000, FCX, CL, TL & Vigor
Item Condition: WV
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
6" front lift for 73-79 F150 or 78\79 Bronco, stock radius arms are available as well so you could put the axles under anything.
Includes 6" super lift coils, 6" Gabriel self adjusting gas shocks, black energy poly c wedges, black poly radius arm bushings, 3" drop super lift radius arm drop brackets, and a drop pitman arm.
$300 for everything. All you need is a rear shackle flip and a drop Trac bar and you'll have a nice lifted truck. Rode great on street and flexed well off road, good pinion angle and caster.
Also have a 31 spline Ford 9" with a welded ruff stuff truss and ruff stuff disc brackets, running Suzuki rotors and Chevy calipers. All new brakes and pads. New studs, lug nuts, wheel bearings, lube locker gasket, new gear oil, new copper washers. Stock 3.55 limited slip carrier.
Dana 44 high pinion 1979 f150, all new brakes including rotors, pads, and calipers. Rebuilt factory hubs. 3.55 open. $300 for both axles, which is less than I have in just the parts. Selling because one tons.
Sero390
22
09-15-2006 07:53 AM
my79f
10-09-2005 12:26 AM
wes8517
1978 - 1996 Big Bronco
08-04-2002 01:03 AM
