wvo 7.3 psd probs with econoline check valves - Ford Truck Enthusiasts Forums
Old 03-20-2014, 03:28 PM
soshea00 soshea00 is offline
soshea00 is starting off with a positive reputation.
Hey guys,
I've seen a few folks on here who seem to be familiar with the deadhead set up that WVO designs recommends and am looking for advice. I've got a 2003 7.3L E350 and have all the parts to do the checkvalve based conversion, but can't get to the diesel fittings on the head without a major overhaul. My mechanic told me it'd take him 5-6 hours to get in there.....has to take out all freon and remove a.c. compressor etc... If it takes him 5 hrs, it'll take me 15 hrs. But my main concern is that I've been told from Leon at WVO Designs that the check valves that you install on the head are known to fail on some vehicles due to pressure spikes and that you'll have to re-install more in a few months to a year or so if you have one of those lucky vehicles. I can't afford that timewise or money-wise, so I'm thought about check valves after the fuel filter bowl, but thats just as buried. So finally my question. Why not just install a check valve on the fuel line from the diesel tank to the fuel filter and add another solenoid (fuel selector valve) on the diesel return that is closed when the veg pump is operating and open when its not? It seems like the easiest install and the most serviceable solution, but I figure that since its not being done, I must be overlooking some basic mechanics of the fuel bowl. Either way, please let me know if this will work or not. Thanks y'all
steve
Old 03-21-2014, 09:35 AM
further info
I talked to Leon at WVO Designs and his only concern about this set-up is the ability of the fuel bowl to handle the pressure that will be created by adding the check valve behind the filter (the pressure the veg pump creates will now ultimately feed all the way back to the fuel bowl).
Does anyone have an idea on whether or not the fuel bowl can handle 70 psi, plus the pressure spikes created by the splitshot injectors?
Isn't the bowl already dealing with the pressure spikes from these injectors anyways?
Any response would be very much appreciated.
Tightwad Mod, WVO, do I need a FPR? JRogersOU 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-17-2014 12:00 AM
didn't purge...now what adamkat22 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 03-13-2013 11:00 AM
Converting a Ford IDI to WVO - Fill me in on the details BombThreat Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 03-26-2008 11:36 AM
The pros and cons of homemade biodiesel vs wvo. derherr65 Bio-diesel, Propane & Alternative Diesel Engine Fuels 66 04-23-2007 09:23 AM
Biodiesel/Vegetable Oil peterjeff Bio-diesel, Propane & Alternative Diesel Engine Fuels 27 01-21-2005 07:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
