finally turbo install
So I finall have a weekend to install my new/used turbo I've got a early banks non wastegate.. so what kind of boost do these typically put out? My pump is fresh with injectors, new head gaskets (6.9). I was hoping to stay under 10 pounds because the engine does not have studs. The turbo has banks stamped on it.
What do you guys think?
Received 3,090 Likes
on
My truck lives a pampered life now. The most I have ever towed with it are 4 sportbikes and a bunch of gear, so it's not exactly what I would call 'being worked'. Also, I purchased the truck with the turbo installed, so I wouldn't have a baseline to compare it to NA vs turbo. But, so long as the revs are up, it doesn't seem to care. EGTs can get up there a little on long grades, but power is there.
I have pics of mine I can load later. The computer I'm on right now isn't photobucket-friendly. Were you looking for pics of the turbo specifically, or the whole truck?
Mike
Mike
My truck lives a pampered life now. The most I have ever towed with it are 4 sportbikes and a bunch of gear, so it's not exactly what I would call being 'worked'. Also, I purchased the truck with the turbo installed, so I wouldn't have a baseline to comapre it to NA vs turbo. But, so long as the revs are up, it doesn't seem to care. EGTs can get up there a little on long grades, but power is there.
Mike
Mike
on
