Windshield wiper mod
Received 4,132 Likes
on
on
That's very similar to what I did with my F1. I used the wipers from a 51-52 and swapped the vacuum motor for an early 90's cherokee. I'm using a cherokee steering column, which is just a gm column with different wire colors. It was easy to use the intermitent switch, stalk mounted, along with washers.
what are you going to install the wiper assembly on?
i notice you have the arms set up for parallel sweep. the 53-56 f100's all have inverse sweep. they move toward each other, then away.
you could change one side arm above the wiper pivot, with the other arm below the pivot, to get parallel arm sweep.
on
Tbb_'62 F100
08-24-2018 05:27 PM
eberf
02-02-2017 11:49 AM
PapaBearYuma
17
01-15-2017 07:31 PM
Wayne Waldrep
12-21-2012 02:06 PM
