Transmission problem
Ok i said i wanted to change to a manual transmission i should be able to do that with out a donor truck i don't need electronics cuz the manual transmission done have any beside neutral switch and thats on the back side of ur clutch pedal and u don't need that really so i should be able to get a manual from behind any diesel motor.
And just for all your information the guy that told me to put transtune in my transmission and drop oil and i put new filter in and put lucus oil transmission additive in it and my light went off and my transmission works perfect so for $80 i fix transmission maybe u should take this and use it
If the light was flashing there's a problem in the trans. That's how these are different than older ones. They tell you something is wrong. If you have ever looked at a clutch disk out of 1 you can see there's not much there to be slipping. Now I know a guy with a 5 speed setup Pm me an I'll see what he wants for it. I think he has everything
Good luck
John
Vsanzbajo
03-17-2014 11:01 AM
Midwest Dually
01-18-2012 11:48 PM
timb1776
06-06-2011 02:55 PM
