Fuel Level Issue - Ford Truck Enthusiasts Forums
Fuel Level Issue
Old 03-19-2014, 09:06 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Fuel Level Issue
As expected, once I got the truck on the road I'm finding issues to fix. In this case, it has to do with an inaccurate fuel gauge.
I filled both tanks, gauge reads full. Drive around for a few days, front tank reads empty. Switch to rear tank, gauge shows full. A few more days, gauge reads empty and front tank still reads empty.
Fill rear tank and it only takes six gallons. Same with the front tank.
I'm thinking the sending units are not working right, but odd that both would be off by the same amount. Is there a way to test them without dropping the tanks? Can they be replaced without dropping the tank?
Thoughts anyone?
Old 03-20-2014, 02:49 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The sending units have a high failure rate on these trucks. The way they are made they wear out prematurely. I suspect both are bad.
If you want to run a test, take the wiring plug loose to the sending unit, find the sending unit wire(usually yellow blue or blue/yellow) and with the engine off'key in run, ground this wire at the sending unit and then unground it. The gauge should read full scale back and forth when you do this. If it does, the guage/wiring and switch are good, the sending unit is bad.
You can get to the front one barely. The rear tank will have to be dropped or the bed taken off.
1987 dual fuel tank issue bmxerbrett 1987 - 1996 F150 & Larger F-Series Trucks 3 05-31-2016 08:24 PM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 09:14 PM
fuel gauge/fuel level issue, 94 F150 jimbo beam 1987 - 1996 F150 & Larger F-Series Trucks 1 12-29-2014 09:33 AM
Couple dual tank issues Iantiler Fuel Injection, Carburetion & Fuel System 17 02-08-2014 01:30 AM
Question on fuel selector valve - dual function reservoir SSellers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-24-2013 12:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
