my rig pig towing not so good
Well right now I'm loaded down 12000 lbs of drill pipe in my 97 f250 and it just can't pull it over 50mph I do have a set of baby swamps comeing still with a new clutch is this going to help my towing abilities mostly this truck is just my got rod to get me to and from the rig but when I do have to tow it's quite a lot any thoughts or other up grades
Received 3,090 Likes
on
You need to tell us what your truck is
gears, trans, tire size, milage, ANY mods that have been done, etc
as for putting 20,800lb load on a trailer behind one of these trucks, YES, you will ALWAYS know it is there no matter what mods you do to it
That truck in the BEST configuration is only rated at 20k GVCW(gross weight of truck, trailer and load), no leads 21k just on the trailer. you are asking WAY to much from your truck, you need a single axle tractor for those weights
Slave, master, or wheel cylinder. There all different. Which one is leaking. Brakes are more important than power. If you have no fluid you won't stop. E-brake on anything is not something you want to have to use. At the weights your running I wouldn't take a chance
