Salvaging old barn wood for bed floor. - Ford Truck Enthusiasts Forums
Old 03-19-2014, 02:15 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is online now
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
I mentioned in an earlier thread about a tree destroying an old barn on my place. I'm attempting to salvage some of the wood to use for bed wood. I don't know the age of the wood since the barn was here before I moved here. Most of the wood was unprotected and in some places really bad shape.
I've spent a lot of time wire brushing and a light belt sanding trying to clean up the planks so that my planer blades won't be totally destroyed on the first board.
They seem to be cleaning up fairly nice, although the planing has be a challenge since the thickness varies considerably.
Question for our wood gurus......since a lot of these boards are cupped pretty badly, I would like to cut them into narrow boards, then plane them and glue them back together. Anyone have experience with wood glues that are truly waterproof ?
Old 03-19-2014, 02:58 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Great Idea! What species of wood is that?
I have a bunch of barn wood around here, mostly pine and fir. Some is so old and dry it just crumbles apart. Makes great firewood.
Your boards look pretty solid.
Old 03-19-2014, 03:07 PM
Drewski 2's Avatar
I'm thinking white oak to have stood up to the weather all these years. The board that I show in the photo that has the end in rough shape was actually down in the dirt. The rotted portion did not extend far up the board. I originally was going to try to cut the boards to eliminate the nail holes, but my wife thinks they add character. I may fill them with epoxy and sand flat before I apply finish to the boards.
And yes....great firewood from the boards too rough to salvage.
Old 03-19-2014, 03:22 PM
mytbtruck's Avatar
mytbtruck mytbtruck is offline
mytbtruck is starting off with a positive reputation.
I might be considered cheep but my wood boat paddles seperated. I cleaned them up and used Gorilla Glue to glue them together. I put a good coat of spar varnish on them and have been using them for about 4 years and they show no sign of separation. It says on label this glue is waterproof. Funny part is you have to wet the wood before you apply the glue.
Old 03-19-2014, 04:37 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Drew,
Wow, that will be a great use for the old boards. I agree with your wife about the nail holes. I also think they would add some nice character.
I don't have any advice on the woodwork, I prefer working in steel, that way when I cut it too short I can always weld a chunk back on....LOL
Bobby
Old 03-19-2014, 05:05 PM
Drewski 2's Avatar
Quote:
Originally Posted by bobbytnm View Post
Drew,
Bobby
So goes my saying .......Cut it off 3 times and........it's still too short!!
Old 03-19-2014, 05:06 PM
Chris 56 f6's Avatar
Chris 56 f6 Chris 56 f6 is offline
Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.
That is white oak. You put a good poly on it and it will last
Old 03-19-2014, 05:16 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Denny, "firsride", is a woodworker by trade and does an excellent job. He'd know a lot about this subject. Maybe he'll chime in or you can send him a PM.
Old 03-19-2014, 08:45 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
An easy way to determine if it is either white oak (very rot resistant) or red oak (not very rot resistant) is to shave off a sliver. If you can blow or suck air through it is red, if not it is white.
Old 03-19-2014, 08:49 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
A metal detector (and a wire brush to remove grit) are your friends right now. Urethane glues use water to cure (even tiny amounts will do it) and is essentially water and solvent proof once cured.
Gorilla glue is a urethane glue.
Old 03-19-2014, 09:30 PM
Drewski 2's Avatar
Quote:
I've done a lot of work with red oak and it doesn't live long exposed to weather. This wood has been hanging on the side of the barn I know 40 years maybe longer.
I hear you on the metal detection and cleaning. It's still rough on planer blades. I can already tell the blades are starting to go as the planer is getting louder as I run the boards.
Is the glue line noticeable using Gorilla glue? I've got very limited experience with it and appearance was not an issue.
Old 03-19-2014, 09:34 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I have been a woodworker for 40 years. The last 20 have been spent primarily in salvaged or reclaimed wood. Today almost half of my business is providing reclaimed wood to builders in this area for new home construction. I am steering the business in this direction as I believe in the older wood and it's virtues, and I've done so much uptight high end cabinetwork for fussy richfolk all my life, I would rather have the young woodworkers I hire in the shop while I'm out on the road in my truck and trailer finding ways to fill the orders. I can't tell you how glad I am to see your post about using the old barn wood for your bed. My clients beg for nail holes and 'character'. I feel your pain with the planer and it's valuable knives. We have 3 different metal detectors and we still hit a nail first run after we change the knives! We have also planed thousands of feet of heavily painted wood. That is really an awful part of the work. I can't wait to see the bed when it's done. Looks like red oak in your pic, but very hard to tell from here.For the cupped boards If you have some extra thickness, run the boards with the 'hump' upwards with a thin narrow stick like a long yardstick under the hump. This planes that face flat without splitting, next flip it over and plane that side flat. I second the gorrilla glue if you don't have the thickness to plane out.
Old 03-19-2014, 10:07 PM
toby tough's Avatar
toby tough toby tough is offline
toby tough has a good reputation on FTE.toby tough has a good reputation on FTE.
Looks like white oak to me too, maybe ash. I've used several different glues and they all have their place. Gorilla glue is some tuff stuff. Bought my wife a maple glider rocking chair when my son was born and over the years it loosened up in spots.One spot broke and I used g.glue on it and the next time it broke about an inch away from the repair. Certainly stronger than the solid wood itself. It does expand quite a bit when it cures so keep that in mind. Doesn't sand down too bad though.
Old 03-19-2014, 10:18 PM
Drewski 2's Avatar
Quote:
Many thanks, I hadn't thought of the stick under the hump. My boards run really wild on thickness and some of the boards are cupped so bad that by the time I plane them flat the board would only be about a 1/2" thick. Those were the boards I wanted to rip in half, plane, joint the edges and glue back together.
I really enjoy planing a piece of rough sawn wood. It's like a treasure hunt for me since you never really know what you're going to get. I'm really bad about collecting driftwood when I go on vacation to a coastal area. I usually come home with a pile of junky looking wood and I can hardly wait for it to dry out so I can plane it.
Old 03-19-2014, 10:19 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
There are a few really old barns around where I grew up that have new siding on them because a company realized they were American Chestnut. They offered to replace the existing siding for free, as long as the farmers gave it to them. A neighbors barn had boards as big as 12' long by 18" wide and over an inch thick.
Your boards are going to make a great looking bed. And with it's age, just consider it NOS.
Scratch built console Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 03-13-2015 08:07 PM
After all these years, I'm still amazed. Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 02-13-2015 01:08 PM
First powered movement since 1987!!!!!! Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-10-2014 02:33 PM
Rims ? bigpetie Excursion - King of SUVs 8 05-31-2014 03:33 PM
4 gallons of water and 1 hr. 55 min. later....... Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 04-27-2014 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
