Repairing HPOP fittings
You need to pull the pump only if it's the plug on the under-side. If it is, pay special attention to the instructions!
The rear plug, and the two hose fittings can be repaired without pulling the pump.
Remember to use the LocTite, and make sure all the threads (internal and external) are SPOTLESSLY-CLEAN and free from any kind of oil.
Also be sure to never turn the fittings (even slightly) once the LocTite has cured.
Pop
Pop
Sent from my Telegraph using IB AutoGroup
The back fitting was easy as well.
When I did mime I removed the IPR and completely drained all the oil, flushed the reservoir with brake cleaner and let it sit all night. The IPR is lower than the ports and will allow the ports to stay clean and dry. Next day I cleaned the threads again and blew them dry, and followed the instructions using the special lock tite. Let it sit again overnight then did an oil change. Been a couple years now without issues. Maybe overkill but I had the time.
Melody Guzman
12-24-2012 07:43 AM
frdf250
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-13-2011 06:49 AM
stevenpalmer51
07-07-2005 08:13 PM
