Front parking brake cable.
Anyone know what the difference is between this:
1948-1952 Ford Pickup Truck Front Emergency Brake Cable - 110-1/2" Long - F2 & F3 - MAC's Antique Auto Parts
and this?:
1948-1952 Ford Pickup Truck Front Emergency Brake Cable - 110-1/2" Long - F1 - MAC's Antique Auto Parts
The first is almost 30 bucks cheaper than the second, but I guess won't work on my F-1?
and this?:
According to the old, original Ford parts catalog, the F1 part, 2C 2853-A is 102 1/2" long and fits 48-52 F1. The 7RD 2853 is for 48-51 F2-3, which also used the F1 style under dash handle before the running change to the trans brake and floor lever some time in '51. It is 110 1/2" long. That extra 8" makes up for the longer wheel base. It's very likely they're functionally the same on the ends. And if the part they're selling for the F1 is actually too long, you'd still have to figure out what to do with the extra length to make it work. Looking at Mac's pictures, it seems the F1 part is rubber coated, which would certainly cost more to make. Or, they're just charging extra for the more popular model and both parts are the same.
I wonder if the difference is really between the type that ran across to the far side of the trans cover, then thru a hole in the firewall, as used on 48 - 50 (?), vs the later style that goes thru the steering column floor plates? Although the other day I noticed that BobbyT's '49 goes thru the column plates...
I had an early '50 way back in the old days. It had the right side exit. Both cables would be about the same length, just that one is a bit more inside and the other more outside the cab. It follows approximately the same path, iirc.
air5dad49
22
10-03-2010 10:34 AM
48fordf3
02-11-2007 05:16 PM
Woodsman_30350
07-20-2004 04:45 PM
Joe51f1
04-21-2003 05:00 PM
