1996 7.3 Powerstroke overheat and shut down
Old 03-18-2014, 11:29 PM
khaleowen's Avatar
khaleowen
khaleowen is offline
I just bought a 1996 power stroke and driving down the freeway the temperature gauge stayed below the first dash. Then the engine temp light came on and the truck began stalling. Thinking it may have blown a head gasket, I pulled off the side of the median and the truck powered itself down in the process. It is now still smoking on the side of the highway. It is an automatic. Haven't checked the oil yet but it was steaming off antifreeze and was everywhere. I did notice a small oil leak before purchasing the pick up but nothing major or unfixable. Any suggestions on the problem?
Old 03-19-2014, 02:05 AM
kliplok's Avatar
kliplok
kliplok is offline
Not any help here but my temp gauge in my '96 stroker has never worked in the 8 years I have owned it
Old 03-19-2014, 07:56 AM
madpogue's Avatar
madpogue
madpogue is offline
Head gasket is unlikely, with that volume of coolant loss. Gotta determine the source of the coolant leak. Could just be your radiator cracked or a hose blew out and you hemmorhaged all or most of your coolant.
Old 03-19-2014, 08:03 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
I see it's been a few hours, any progress? Maybe re-fill with coolant and see what happens.
When the motor looses enough oil, it won't fire the injectors and it'll shut down. It's near impossible to damage one of these motors by just running out of oil because of this 'feature'. I wouldn't worry too much about loss of oil as a cause/problem of overheating.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 03-19-2014, 09:24 PM
khaleowen's Avatar
khaleowen
The heater was also not working and there is some coolant in my valve covers. There is no sigh of coolent making it's way to the heater core either is it possible the thremostat is not opening for some reason. Thanks for the help guys.
Old 03-19-2014, 09:51 PM
madpogue's Avatar
madpogue
madpogue is offline
Don't worry about the thermostat, the oil, the head gasket, or anything else until you find the LEAK.
Old 03-20-2014, 05:34 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Originally Posted by khaleowen
............. and there is some coolant in my valve covers.
IN or ON?
IN is big trouble, ON is a leak.
__________________
Old 03-20-2014, 11:40 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
My vote is a stuck thermostat. Flush it and put in a new thermostat, then try it again.
Old 03-20-2014, 12:38 PM
khaleowen's Avatar
khaleowen
IN the valve cover thats why I'm saying I have a bigger problem than a thermostat possibly cracked head most likely or a head gasket. Maybe even a trashed motor any thoughts.
Old 03-20-2014, 08:26 PM
oldbird1965
My guess is blown head gasket but I don't know, good luck.
Old 03-20-2014, 08:35 PM
fordpride's Avatar
fordpride
fordpride is offline
Pull the valve cover, refill the system with water(don't waste cash on coolant) and pressurize the system and see where it's coming from
Old 03-30-2014, 09:40 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Did you find anything out?
Old 04-14-2014, 08:44 PM
khaleowen's Avatar
khaleowen
The block is cracked sorry it took so long to get back thanks for the help though if anybody is looking for 7.3 parts let me know.
MDSLIGHT
1999 to 2016 Super Duty
01-31-2016 06:57 PM
77cougar
01-31-2014 02:38 PM
tm3912
05-12-2006 08:11 AM
tm3912
04-22-2006 12:30 PM
atw54
1983 - 2012 Ranger & B-Series
11-14-2004 10:43 AM
Quick Reply: 1996 7.3 Powerstroke overheat and shut down
