Brakes
Brakes
I have a 1972 f100 2wd sport custom truck with drum brakes. I need to know if there is a complete conversion kit for disc brakes? Also I think that the 72 year came with disc brake option and I was wonder if I could just which the brake out with 72 that has disc brakes? If anyone know please help. Tired of going in circles.
Albert, Welcome to FTE and the Bumpside Forum.
Yes sir buddy, Find and buy a 73-76 for FE 360 engine or 73-79 for I6 or 302 that also has the transmission that you currently have or wish to swap to. The 73+ will have every little part needed, all bolt hole swap. I bought a 76 360/C6 for my 66 F100, sold parts that I didn't need and ended up -0- in cost.
Make a plan you can make it happen. Don't get in a rush you can find your donor. Live in a gated community and can't bring a donor in, rent a space for a month. Make it happen, no excuses.
John
John
There is current thread on here "Never saw these before" or something to that effect that is a new bracket that allows pretty simply not much expense disc brake conversion. Also, check the sticky at the top as it has tons of valuable information that Joe was talking about. A wealth of information is available right here for you if you are just inclined to search. If you have any issues or questions along the way there are many talented people on here who love to help us newbies.....
The other way is to find a 71 or 72 but you will need the corresponding linkages because the steering arm positions are in a slightly different position and your linkages will rub on the radius arm pass-throughs.
73-79s will also work albeit a bit more involved. Read the tech thread sticky for links to disc brake swapping info.
I actually went with the Master Power option. They send you everything you need to to the swap. It is real easy basically have to take spindles off your truck and put the ones they send you on. It is pre-assembled with new bearings, rotor, caliper etc. Also get a new master cylinder, booster and prop valve. I did it in a couple of days after work. Also, if your truck doesn't have power steering, this would be a great time to upgrade to that as well. When you have the master cylinder out of the way it makes is easy to get steering column and box off.
Yes it'll swap. Read the article on disc swapping here on FTE and at Fordificafion for info on kingpin variations.
Albert, it was in that time frame that Ford switched from 100 to 150, both are 1/2 ton rated trucks, either will work as donor.
You can swap parts or complete I-Beam sets, I have seen guys beat on king pins for a half day, so there is no advantage to not swap the complete set. It has been a president for a while that every time a member comes back here with a problem he swapped parts rather than complete sets. I know when I am at the parts counter to ask for 76 year parts for about everything below the chassis of my 66.
John
John
Originally Posted by Albert f100
I have a 1972 F100 2WD Sport Custom with drum brakes. I think that the 72 year came with disc brake option.
1973 was the first year that F100 2WD's were available with disc brakes.
1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
All 1975/79 F150 2WD's came with power disc brakes as standard equipment.
Sam's1967
146
01-15-2017 02:08 AM
Beelicense
02-07-2008 02:09 PM
