ELC coolant/entenders
So it's time for me to flush coolant. Last time I went with G-05 gold in my 2002. I had a hard time finding ELC locally. After reading more, it seems some ELC's require the addition of an extender @ 3 years into the cycle to get the high mileage/years coverage advertised. Trouble is, I have not been able to find info on the extenders or where to obtain them.
After reading on Peak Final Charge Global Extended Life Coolant, it seems no extender is required. Only testing freeze point and top of with a 50/50 mix of the coolant. I've attached a link from Peaks FAQ describing maintaining their coolant. Anyone else using this stuff? Thoughts?
PEAK COMMERCIAL & INDUSTRIAL | FINAL CHARGE | EXTENDED LIFE COOLANT/ANTIFREEZE | FAQS
I have Delo ELC in my rigs. Delo ELC is good for 750,000 miles or one million with an extender.
I'm not worrying about the extender.
Stewart
I am interested in another aspect, and will be researching the use of any of the manufacturers' "converter kits", wherein one only adds a formulation that converts conventional coolant into ELC.
Seems just too easy-peasy, but large fleets go through this "conversion", and I have seen no negative subsequent reporting.
Of course, the "conversion" stuff is kinda' hidden from public consumption.
Anyone know anything?
Where's Gooch when you need 'im?
Pop
Pop
I'm using the Delo as well, and from memory I'm pretty sure the back of the bottle says the extender doesn't need to be added until 500,000 miles/4 years.
I agree, the ELC is far, FAR too hard to get ahold of. And I leave near one of the busiest interstate junctions in the country, with many truck stops and OEM dealers.
I'm sure the Peak Final Charge is a good product, and I believe I remember it being mentioned by Gooch as recommended.
Here's a story for anyone interested in reading:
I bought my recent T444E water pump from the local Int'l dealer. When I called to place the order, I specifically asked if they carried Rotella ELC Concentrate AND 50/50 mix; to which the salesman replied: "Oh yeah, we have cases of both. I'm looking at them as we speak".
Sweet, that was easy.
I go in to pick my pump up, and I only see cases of 50/50... Dozens of them. So I ask the dork behind the counter to give me 4 gallons of concentrate.
He replies, "I no longer stock concentrate. Too many people not using distilled water".
Me: "Well, I have 20 gallons of distilled water in the back of my truck, wanna see?"
Him: "Doesn't matter, I won't do it. Sorry."
Me: "If I were you, I'd be more worried about warranty claims on a cracked block due to weak freeze point because you refuse to sell a concentrate to adjust it after flushing."
I just got another apology and refusal to sell me any. I proceeded to drive all around town to no avail, and had to use our company stock of Delo.. Which I was trying not to do. And I absolutely will not be using Central Maryland International Truck in Hagerstown, MD again.
Conventional "green" coolants start life as phosphoric acid. OAT ELC's start life as carboxylic acids.
If you find any info I'd really be interested in how they do the conversion.
Stewart
It's kinda' involved, wherein you first need to pull a sample of your current coolant and send it off to determine if it's suitable for conversion. The glycol already needs to be up-to-snuff, though. After you're done, another sample needs to be sent to prove it's working as planned.
The conversion apparently somehow disables the SCAs and anti-corrosives, causing them to precipitate out, and adds in the OATs. The ethylene glycol remains the same.
Beyond that, the chemistry is kinda' vague to end users.
Here's a web page from 2004 that might lend some insight:
Shell Introduces New Coolant Conversion Kits - TopNews - Aftermarket - TopNews - TruckingInfo.com
After some digging and looking around this afternoon, I suspect I'll never convert to ELC in this manner.
I need to re-think my little part of "saving the environment", and just dump it (responsibly, though)!
Pop
No easy access to anything(CAT, Delo,Rotella,Mobile Delvac,...) except the Peak from the Irish. Their description mentions extender use vs. Peaks FAQ attached in first post. I'll never hit any of the milage, but would like the peace of mind for the 6-8 years many of these ELC's state.
We are just now getting the Irish parts stores here in town, I usually have to drive to a truck stop over 35 miles away to get it otherwise.
Guys i have a question about coolant and i will admit im lost with all the picks. I bought a 01 7.3 in a van. A ambulance that was retired at 200K. How in the heck would i know what coolant they used, All i know is green lol. Any ideas how to test it for additives and or what to use to change it. thanks again
