Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 03-18-2014, 10:48 AM
PlumCrazy7 PlumCrazy7 is offline
PlumCrazy7 is starting off with a positive reputation.
AOD rebuild
Hello all, I thought I'd document my rebuild and upgrades on my AOD. It's being repaired to go in an 88 Bronco with 302 with GT40P heads and headman headers. I had to rebuild it because I used an E4OD/C6 flexplate with the 302 I swapped in and it pushed too far and chewed up the pump flooding the trans with aluminum.
I ordered:
Napa OEM overhaul kit-$176, came with RAYBESTOS clutches and steels, not performance stuff but I think it speaks for the quality of the kit.
Baumann Valvebody Recal Kit-$60
Seal installer Kit-$99 on ebay ordered after slightly nicking a lip seal
Discontinued lip seal $20 order from KC
Torque converter flush-?? I'm not sure where to get this done, any suggestions are appreciated.
I just spent two nights cleaning the valvebody and installing the valvebody kit, there was ALOT of aluminum dust in there. Everywhere else was fairly clean except the forward clutch piston, kind of cool how it was distributed. I'll be sure to post results on the valvebody kit as I haven't seen anyone reviewing Baumann's kit.
Old 03-18-2014, 10:55 AM
Got the valve body reassembled, it was a bear, next time I will be taking pictures of each valve bore's contents.
I used my piston installer kit on the forward drum and it is a life saver! piston went in slicker than snot with the tools, kit was $99 from a company on ebay which is about 60 bucks cheaper than everywhere else.
From my experience do not attempt an AOD rebuild without the piston install kit, its not worth the hassle and worry of nicking seals. Plus individual seals are almost impossible to come by.
Old 03-18-2014, 01:20 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Oh.. I feel your pain... I did the exact same thing on my first swap years ago and screwed up a perfectly good trans. Post up as much detail as you can on this rebuild.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1994 3.0L 5-sp x-cab Ranger 3.45, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Old 03-18-2014, 02:02 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Can you post a link or the seller of the install tools you got.
__________________
JR Strout..aim UNTAMND..00psd4x4ccsbLariet37sTwinTurbo
http://www.youtube.com/profile?user=untamnd#g/u
90 F150 xlt lariat supercab 4x4 long bed 5.8 auto red interior (stock for now) 61000miles
67 Mustang GTA Fastback 390 UNTAMND.com
Old 03-19-2014, 04:44 PM
tools:
I'm on the reverse clutch now and the piston install tool from that kit is extremely tight and I can't get the piston through the outer seal protector let alone get it in the reverse drum!
any suggestions before I take an emery cloth to the tool?
Old 03-24-2014, 07:34 PM
Got the outer reverse piston seal protector opened up with sand paper and polished it with emery cloth. Installed the clutches and other pieces in the reverse drum and it was the only one to be within spec once installed. I have put together the forward and direct drums and am waiting for correctly sized snap rings, this might be a hassle as ford has discontinued snap rings for at least the direct drum.
Old 03-31-2014, 05:01 PM
I read a build up on a different site on a 4R70W where to get another clutch in the forward drum he omitted the wave plate, and replaced the pressure plate with the accompanying steel. Since the wave plate simply acts to cushion the shift and I was way out of spec for some reason I took the wave plate out and had an almost perfect .067 inches of clearance.
I have started to put it all back together I have the servos in and am almost ready to install the intermediate clutches.
My final problem is the torque converter, do you guys think I'm safe with a flush or do I need to buy a new converter?
Old 03-31-2014, 05:10 PM
Conanski's Avatar
Was the collar(the part that goes into the pump) of the TC chewed up or scored? Mine was and it always leaked.
__________________
Old 03-31-2014, 09:28 PM
The nose of the hub is good, not sharp or visibly wore. I just don't want to drop $250 on a TC as funds are pretty tight right now, however having a junk trans again isn't on my want list either.
Old 03-31-2014, 10:34 PM
Bruners4's Avatar
Bruners4 Bruners4 is offline
Bruners4 is starting off with a positive reputation.
Check to see if the paint is discolored on the front side of the TC. If it is, the clutch has been slipping and needs replaced.
__________________
'91 F150 Supercab XLT Lariat Shortbox 4x4, 5.8L, E4OD, manual BW1356, 2.5" lift, 32x11.5x15 Falken WildPeak, 4.10 LSD F&R, Warn HD hubs.
They call me Dave
Old 03-31-2014, 10:41 PM
Conanski's Avatar
Quote:
There is no clutch in an AOD converter.
__________________
Old 04-04-2014, 07:07 PM
I'm up to the intermediate clutch in the rebuild, however I'm not technically within specs. The ATSG manual says clutch depth should be 1.634-1.636.
I'm at about 1.660 and I measured all of my steels and they are all .062-.065, a hair smaller than the smallest selective steel plates that can be ordered.
A guy rebuilt his 4R70W and said Ford lists clearance at 1.634-1.677
Does anyone have a repair manual by ford or should I check with the local dealership to check this info?
Old 04-08-2014, 11:16 PM
Alright I've heard a few people say as long as the clutch pack is deeper than spec it's alright as it won't interfere with the piston when not engaged so I'll install the pump and if I don't feel drag I'll roll with it.
I've been told to buy a new torque converter by a guy who I think knows his stuff. I'm looking at Monster Transmission's AOD TC and am thinking the heavy duty 1600-1800 stall. AOD Torque Converter, 1600-1800 Heavy Duty, Low Stall, - Torque Converters FORD AOD Performance - Monster Transmission & Performance | 800-708-0087 | Fast FREE Shipping!
Do you guys think that is a good stall for a prepped 302 or do I need to step up to the 1900-2300 stall
AOD Torque Converter, 1900-2300 Stall, Heavy Duty, Torque Converter, - Torque Converters FORD AOD Performance - Monster Transmission & Performance | 800-708-0087 | Fast FREE Shipping!
Old 04-08-2014, 11:23 PM
UNTAMND's Avatar
Daily driving, towing get the lower one. Mud runs and off-road I'd get the higher one.
If you don't tow, and can cruise in od where you live, I'd go with the higher stall. Will liven up the motor and get it in its power range for having fun. You'll need a good trans cooler. Stacked plate design. Not a single pass loopy loop crappy thing.
__________________
Conanski's Avatar
The higher the stall the more heat it'll generate and the worse the jump will be at the shift from 2nd to 3rd when the TC is bypassed. Unless you're building the trans for no TC bypass(lockup) in any gear then I'd suggest you get as close as possible to a stock stall speed.
__________________
Similar Threads
AOD rebuild PlumCrazy7 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-12-2014 11:29 PM
88 Bronco AOD Build PlumCrazy7 1987 - 1996 F150 & Larger F-Series Trucks 2 02-04-2014 06:18 PM
Ranger transmission issues bustech81 Clutch, Transmission, Differential, Axle & Transfer Case 2 04-08-2011 01:31 PM
VALVE BODY MODS tinker934 1999 - 2003 7.3L Power Stroke Diesel 8 09-09-2010 10:38 PM
E4OD shifting bad - Please help, I need to get home AggiePSD Clutch, Transmission, Differential, Axle & Transfer Case 6 01-13-2003 02:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
