Pre-Pump Fuel Filter Question - Ford Truck Enthusiasts Forums
Old 03-17-2014, 10:04 PM
bflora bflora is offline
bflora is gaining momentum as a positive member of FTE.
All,
Moving this over from the "bio-fuel" sections. Anyhow, new here, and was hoping for a bit of assistance as it relates to after market fuel filters. I recently had the 'Driven Diesel Performance' hutch kit installed (here Driven Diesel Fuel Tank / Pre-Pump Kit), and the BF1212 filter appears to have impacted my fuel pressure due to the low micron rating.
It's my understanding it has sufficient flow rating, but the truck just doesn't have the same power it did before this mod. Unfortunately, I do not have a fuel pressure gauge, so I'm blaming the filter without any real proof it's the culprit.
Maybe I'm guessing wrong, and could circumvent the filter as a test, but thought trying something like BF7759 (aka "strainer" type) would be an easier task. After a some research, I can't use the BF7759, as it's a 1-12 and my filter head is a 1-14.
Note, still have my OEM fuel bowl, with a newly installed Motorcraft filter.
With all that said, is a BF1212 style the best for this set-up, and if not, what fuel strainer/filter is recommend pre-pump (OEM rail) to ensure optimal fuel pressure along with extending the life of my OEM fuel pump? I'd rather not install a Carter "assistance" pump to pull from the tank to the filter, as I first want to determine if simply adjusting the filter is the first step here, and it's just another thing to worry about.
Old 03-17-2014, 10:18 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
ya, that i think is, way to low of a micron rating being pre-pump and also having the stock fuel filter. I'd install this
Wix 33239 & Napa 3239 Fuel Filter: FleetFilter Secure Online Store
here's a list of 1-14 threaded spin ons
http://www.fleetfilter.com/mm5/merchant.mvc?
Old 03-17-2014, 10:26 PM
Thanks for the quick reply!
Old 03-17-2014, 11:21 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Pre-pump should be much more of a screen than a filter. A simple inline filter would be sufficient.
If you are using alternative fuels, it should be filtered for particulate matter before putting it in your tank to remove the big stuff. The prepump filter is just to protect the pump.
Old 03-18-2014, 01:09 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
i never had a problem with the 1212,,did you give time for the air to work out of it?? are you sure you have a nice tight seal from the tank all the way to the heads?? you really need to put a psi gauge on there..
here is the specs for the 1212
Flow Rates:
210 GPH @ 1 PSID
300+ GPH @ 3 PSID
Other Specs:
Capacity in Grams: 32.4
Filtration: 4 micron @ 86% / 20 micron @ 99%
Burst Pressure: 150psi
Collapse Pressure: 100psid
you can also run the baldwin 1252..it is whats recomended for the high flow pumps like the fuelab..here is the specs for the 1252
Flow Rates:
Greater than 210 GPH @ 1 PSID
Greater than 300+ GPH @ 3 PSID
Other Specs:
Capacity in Grams: 59
Filtration: 9 micron @ 86% / 40 micron @ 99%
Old 03-18-2014, 05:30 AM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I have 3 filters. The pre-pump filter is high micron (to catch chunks), the other two in the engine compartment are around 10 micron.
Old 03-18-2014, 08:50 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I did what you did, installed a fuel pressure gauge, filled my underwear, then installed a proper pre-pump screen.
Before:
After:
Old 03-18-2014, 09:05 AM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
I Agree.. Trying to find what micron level of the filter i used ? . I think it was around 30-50 but can't find it. Been in there since i installed it.. I just noticed it has been a few years and i probably should pick a new one up. http://www.ford-trucks.com/forums/11...t-numbers.html
I would think anything less in size than the screen size in the pump is fine as long as you still have your factory filter.
Old 03-18-2014, 09:14 AM
I really appreciate all the replies, and thoughts so far!
I agree that I need a fuel pressure gauge, but not something I can do immediately. My local pats store has the Napa 3239, so I'm going to try it later today or tomorrow.
Anyhow, I left out part of the story - when I had the hutch installed with the BF1212, I didn't make it a mile down the road until my fuel pump went out. It's my understanding the fuel bump was weak from the in-tank OEM pick-up and screens being clogged, and the primary reason I did the mod. Anyhow, after cleaning the OEM screens a few months ago, the truck ran fantastic, but I wanted the screen outside of the tank, so I could change without dropping it. To clarify, I ran the truck for weeks after cleaning the in-tank filters, and then later had the hutch installed.
Why was my filters clogged? I think for many reasons, but primarily due to my fuel neck rusting out, which was the first thing I replaced.
Again, I'm guessing the low micro filter was the last blow & just enough to end the life of the pump
Before the mod, with a "weak pump", I still had some impressive "get-up and go", and note, I didn't actually do the install myself, but sure the shop got all the air out, as it's been on for a few weeks now.
Lastly, the BF1212 seems like a great filter, but when I get over 2000 RPMs (or what I'd call putting it on a "load" test), it just doesn't have the power it did before the mod.
Maybe I don't need a filter, as my tank is clean as a whistle and my fuel neck is brand new?!?
Old 03-18-2014, 09:27 AM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
Quote:
I would have changed my underwear before changing filters, but different strokes for different folks.
Old 03-18-2014, 04:15 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
FWIW, I've been running a Dahl 2 micron pre-pump filter on my OBS for probably 6 years now with ZERO issues. Having a proper filter on the suction side of the pump doesn't hurt anything....
I'm fixing to install the same kit from Strictly Diesel, but I'm also installing the post-pump filter kit, and regulated return w/ bowl delete. I already have the stuff, just need to install.
Old 03-18-2014, 05:15 PM
@strokin'_tatsch - Are you running an OEM rail-mounted fuel pump?
Old 03-18-2014, 05:30 PM
Quote:
I have run both an OEM SD rail mounted pump and a walbro pump on this setup. It worked fine. Eventually I started to see a pressure drop with the stock SD pump when I'd go WOT, hints the switch to a walbro pump. The SD pump started having trouble holding pressure after I switched to bigger injector nozzles. I believe that if I were to change the design of the regulated return on that truck I wouldn't have had the pressure drop with that pump. We'll see soon enough. Same size injectors are getting thrown at my SD with a better RR design and the stock SD pump.
Old 03-19-2014, 06:32 PM
Well, got the Napa 3239 on there, and can't report it officially made a difference - I didn't really get to test, as this ("Shifter Shortage") http://www.ford-trucks.com/forums/10...tch-short.html happened to me during (after fueling, I went to put the truck in Drive, and heard a pop) - SOB!!!! Anyhow, just proof I need to get to reading more content here on the forum to determine what other preventive maintenance if needed - getting towed sucks!
Old 03-19-2014, 09:24 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
I pull 19k gross up hills,with no problems using Strictly diesels Prepump BF1212 filter,factory lift pump has 218k with truck in signature.
Baldwin BF1212 prepump water separator and freezing conditions 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 02-26-2014 09:16 PM
Arctic Blast/Diesel Gelling survival kit white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 37 01-27-2014 12:06 AM
Pre-Pump Filtration - Questions re Best Practices F250_ 1999 - 2003 7.3L Power Stroke Diesel 25 01-01-2012 08:54 PM
Hutch Mod Concerns jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 17 10-08-2009 07:25 PM
What's the micron rating on OEM fuel filter mongo75 1999 - 2003 7.3L Power Stroke Diesel 11 06-15-2007 02:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
