strange noise fro gt38r
Old 03-26-2014, 12:15 AM
sudsmcduff's Avatar
sudsmcduff
sudsmcduff is offline
was climbing a steep grade on freeway towing around 9k trailer. od button was off. had truck in 60hp to mode. when i laid into it, turbo starting making a differnt noise. kinda a squealing noise off and on. it stopped when i eased off the pedal. do these turbos make noise under heavy load? thanks for reading.
Old 03-26-2014, 06:41 AM
Tugly's Avatar
Tugly
Tugly is offline
I had that happen to me a few times before I figured out mine was. If you recently topped off your coolant, when you build heat from putting the juice to it - the degas cap squeals when it vents.
One other item - you have the loudest turbo with the loudest air intake, and that 6637 is no match for a 38R. I went with the S&B to get my boost and backpressure in balance. I haven't heard anything objectionable since upgrading my intake and leaving the coolant at a lower level.
Old 03-26-2014, 09:23 AM
bulla's Avatar
bulla
bulla is offline
I've heard of the belt squealing under load giving a high pitch squeal. Just a faint lil whistle.
Old 03-26-2014, 10:01 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Correct me if I'm wrong, but isn't the GT38R is the stock turbo, as opposed to the GTP38R being the ball bearing model? Does it sound like this?
EDIT: I see in your sig it lists the GTP38R. Is this problem with your truck, or is it a different one?
Old 03-26-2014, 05:29 PM
t.scottNDU's Avatar
t.scottNDU
t.scottNDU is offline
I think stock is GTP-38 and the ball bearing model is GTP-38R.
Old 03-26-2014, 05:46 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
You're probably right. I can't keep those numbers straight, lol.
Old 03-26-2014, 05:53 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
GTP38 is stock.
38R is ball bearing.
Stewart
Old 03-26-2014, 06:27 PM
Baatzy's Avatar
Baatzy
Baatzy is offline
Pikachu, did you ever find out what caused that noise? Mine makes the exact same noise on a stock turbo, other than that it doesn't whistle at the end, it is more of a throaty whine.
Old 03-26-2014, 08:05 PM
sudsmcduff's Avatar
sudsmcduff
thanks for all the info. is the 6637 the wrong set up? i cant get enough of the turbo whistle.
Old 03-26-2014, 09:15 PM
Tugly's Avatar
Tugly
Tugly is offline
Get an AFE... that'll do ya.
I think of it as 38Roller bearing.
That was some nasty surge up there... hard on the turbo.
Williams65
6.4L Power Stroke Diesel
12-22-2017 08:36 AM
RobFlag
6.7L Power Stroke Diesel
09-26-2016 05:29 PM
shultzaberger
11-04-2014 02:38 PM
elcapitan
04-18-2011 08:39 PM
southernpridelc
07-29-2005 07:34 PM
Quick Reply: strange noise fro gt38r
