How much of a pain??????
I bought a 1990 Bronco that someone had pulled the factory motor and replaced with a carbed 302 that is on its last leg. I have a friend that has a complete 1997 F150 that his son rolled. I can get a 4.6 and overdrive trans with only 67000 miles. My question is how much a pain will it be to install the 4.6 in my Bronco?
Anything is possible. It's not a question of how fast do you want to go......it's how much money do you have!!!
A lot of the hot rodders and truck builders using the Ford mod motors (4.6 & 5.4) use a harness from The Detail Zone Telorvek Design. I've seen them, read about them, but.....it's above my pay grade!!! I think they will build what you need.....but like I said....it's above my pay grade!
They do make an carb intake set up for the mod motors. Then you're looking at tranny/transfer case, all custom mounts, A/C hose fabrication, all new fuel supply, cooling, exhaust, and on, and on and on!!!
Is it doable.....certainly! Feasible.......that's up to you!
A trophy truck bronco certainly is. However, it would cost a lifetime and a half to pay for the work...
