Thoughts on rear fuel tank vent mod
Thanks again Chris. I did knock the insert out of the front one when I did the mod. It came out fairly easy. I just cut almost all the way through like Glenn said and knocked it out the bottom with a hammer and chisel.
It's so tight there, that's why I was thinking of a different way. Ya if the tank was down and empty you could locate a spot that will work and drill a hole, I was just looking at it in an easier way! I'm just gonna pull the inner out like Chris said sometime and try it like that for a bit.
tgun
13
06-07-2019 08:12 AM
Kouwenberg7.3
06-15-2014 06:22 PM
hhight
03-30-2014 06:35 PM
AlanMac
03-18-2013 08:59 PM
