F600 Vin Decode
F60 = F600 2WD (gas).
0 = No such VIN engine code as 0 or O / Could be a C = 330 2V M/D FT engine or D = 330 2V H/D FT engine.
U = Louisville KY Assembly Plant.
W01032 = 1975.
194" Wheelbase.
N = Exterior color N not listed until 1978.
F602 = F600 2WD (gas), 19,200 lbs. GVWR
4B8: 4B = Heavy Duty Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F2K: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity // K = Ford 5,500 lbs. Capacity Front Axle with P/S.
19,200 lbs. Gross Vehicle Weight Rating.
Welcome to FTE
W01032 = 1975.
194" Wheelbase.
W01032 = 1975.
194" Wheelbase.
Do you know if that “//K” code for the 5,500 front axle was used for the F600/F700 thru 1986?
That would really help my search....
thanks,
Robert S
