Which Filter and Size - Ford Truck Enthusiasts Forums
Old 03-17-2014, 04:15 PM
bflora bflora is offline
bflora is gaining momentum as a positive member of FTE.
Moved to '1999 - 2003 7.3L Power Stroke Diesel' section.
All,
New here, and was hoping for a bit of assistance as it relates to after market fuel filters. I recently had the 'Driven Diesel Performance' hutch kit installed (here Driven Diesel Fuel Tank / Pre-Pump Kit), and the BF1212 filter appears to have impacted my fuel pressure due to the low micron rating.
It's my understanding it has sufficient flow rating, but of the truck just doesn't have the same power it did before this mod. Unfortunately, I do not have a fuel pressure gauge, so I'm blaming the filter without any real proof it's the culprit.
Maybe I'm guessing wrong, and could circumvent the filter as a test, but thought trying something like BF7759 (aka "strainer" type) would be an easier task. Note, still have my OEM fuel bowl, with a brand new Motorcraft filter.
With all that said, is a BF1212 style the best for this set-up, and if not, what fuel strainer/filter is recommend pre-pump (OEM rail) to ensure optimal fuel pressure along with extending the life of my OEM fuel pump? I'd rather not install a Carter "assistance" pump to pull from the tank to the filter, as I first want to determine if simply adjusting the filter is the first step here.
Hutch- how often do you change filter? Jointasset 1999 - 2003 7.3L Power Stroke Diesel 6 03-13-2016 10:18 AM
FUEL PRESS. GA. TWITCHIN 250 STROKER 1999 - 2003 7.3L Power Stroke Diesel 20 04-09-2015 11:06 AM
Pre-Filter video post Hutch Mod snknby123 1999 - 2003 7.3L Power Stroke Diesel 26 09-26-2014 01:07 PM
Pre-Pump Fuel Filter Question bflora 1999 - 2003 7.3L Power Stroke Diesel 28 03-26-2014 07:01 PM
Arctic Blast/Diesel Gelling survival kit white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 37 01-27-2014 12:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
