1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What Rear end on 2012 F350 PSD Dually
Old 03-17-2014, 02:59 PM
gkerlin's Avatar
gkerlin
gkerlin is offline
Been trying to find out.
I have a 2012 PSD F350 Dually Crew Cab Lariat. It is pretty much towing a 17k fifth wheel or its parked.
Was just in for 45k Service (severe duty) and the Ford Diesel Supplement says to change the Transfer fluid and rear end fluid if I have a Dana rear axle.
I could not find any info on the rear end that says what make axle it is. The drive shaft says Dana/Spicer but that is it.
So I go to the dealer today and he says it's not a Dana so it does not need a fluid change. So I ask "what make is it? And he couldn't definitively answer me. (I have an inquiring mind)
My understanding on my year and model is that its supposed to be either Dana or Sterling and both of them should say it?
Long story short he (Tech and Service Mgr) goes online to Ford with my VIN and all he could come up with was that I have a 3.73 rear…. Duh… I know that. Who makes it?
So they are trying a different route to find out for me - said it might take a few days to get back to me… not confident in that.
I spent hours this weekend trying to find out info to determine what it is but no luck.
Anyone have an idea as to how I can identify it?
Old 03-17-2014, 03:28 PM
bryyce62's Avatar
bryyce62
bryyce62 is offline
Pretty sure it's a Dana 80. F450's all had 4.30gear. F350 could prolly get a 3.73.
I used to have a '13 order guide in .pdf, but at the moment it's MIA
Old 03-17-2014, 04:00 PM
jimmac28's Avatar
jimmac28
jimmac28 is offline
X2
Old 03-17-2014, 04:06 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Originally Posted by jimmac28
X2
Correct. It's a Dana 80. Although I'm not really surprised, it's kind of frustrating that a dealer can't even tell the difference. The Sterling is only available in the SRW trucks and the 3.73 is only available with the diesel in the DRW F-350. To get a 3.73 in an SRW, you have to get the gas engine.
Check out page 74 on the link below.
https://www.fleet.ford.com/TRUCKBBAS...Pickups_SB.pdf
Old 03-17-2014, 05:29 PM
gkerlin's Avatar
gkerlin
gkerlin is offline
Thanks for the info.
They said the rear was not a Dana nor a Sterling. I said as far as I knew it had to be one of the two and everything I knew said it was a Dana.
Frustrating when I know more than the tech. (and I know little)
Dealer did not do half the things on a 45k service that they were supposed to do.
This was the third dealer in my area I've been to where they just don't seem to have their sh__t together. Now I have to look for a 4th.
Old 03-17-2014, 06:33 PM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
Or you could do some of it yourself and know it is done right. I would change the fluid anyway if it is due. Alot of smaller maintenance stuff isn't that hard to do and it is always good to know your truck just in case you are on the road.
Old 03-18-2014, 07:48 AM
gkerlin's Avatar
gkerlin
gkerlin is offline
I usually do a lot of the small stuff (filters, oil changes etc), but like a fool I was talked into the pre-paid maintenance when I bought the truck. I've only used 4 of the 8 visits so most is going to go unused.
I figured for the bigger visits I'd let a "pro" do the work so it gets done right. I always need to spend time trying to figure out how to do the next job. What fluid to use, how do I drain the transfer case for instance… what new tool do I need? Sometimes theres just not the time to do it all when it needs to be done.
Just got a call from the Dealer…. Guess what? It has a Dana. I told him that it's really disappointing that I (a dumb consumer) seems to always have the answer for the tech.
I know that there are Ford Techs out there who know their stuff. It just hard to find them sometimes and in my area even harder. I've been to dealers in Idaho and California where diesels rule and it seemed as if they really knew the truck. Here in the southeast though… have not had much luck.
This is the 4th time now at a dealership where I've gotten info off of the net or this forum and had to correct something that was done wrong. So its time to look for dealer number 4.
Old 03-18-2014, 09:47 AM
powerstroke72
Man, sorry you're having such a tough time with dealers. I've been through similar experiences as well and it's no fun at all. And it's really a shame when you have to provide them with information they should already know.
As for the techs, I've generally found a ton of great techs in every dealership I've used over the years. While I'm sure there are some that aren't so great, I believe most of them are well trained and very capable mechanics. The biggest challenge I've found is dealing with the service advisors and / or managers, which is another issue all on its own.
brokeasajoke
09-28-2013 01:12 PM
JamesB128
07-10-2012 10:25 PM
raptor131
06-01-2009 08:21 AM
dave3406
11-01-2008 10:21 PM
78SupercabPowerstroke
06-16-2005 10:55 PM
Quick Reply: What Rear end on 2012 F350 PSD Dually
