Dangerously slow pulling out in front of traffic
Had the same issue on mine, seems the only way to fix it at this time is a programmer.
The first week i had the truck I pulled out into traffic and it went dog slow then gassed it and the traction control kicked in. It just feels like you have very little control over your vehicle. Also noticed if you are cruising at about 40 and need to get between cars it takes about 3 seconds for the truck to down shift and think about doing something, by that time you lost your opportunity. At least in my old 2005 diesel you had turbo lag but then you had full power, do miss the extra torque though.
When started cold, my truck refuses to accelerate normally no matter how much throttle I give it. There's no miss or roughness at all. It just doesn't respond to additional throttle input. When it does this, it takes about a quarter mile to reach 45 - 50 mph. By the time I reach a stop sign about a mile from my driveway it will accelerate fine. It did it again this morning when it was about 10 degrees out.
Luckily for me, I live in the country and when I leave work the truck is starting to warm up by the time I reach a main highway.
BTW,,,,I traded my 2003 7.3 F250 XLT SWB EXT in on this truck in December 13 and have haven't looked back.
2011 F350 XLT EXT CAB SWB 4X4, 6.2L, 3.73
I'd be surprised to learn if Ford programmed this sluggish response. It is unsafe from the standpoint that a driver becomes accustomed to the normal response of his/her vehicle. If I make a judgement to pull out into traffic because I am confident I can get out of the way, and then my truck does not perform the way it otherwise consistently does, I could end up in a serious accident. Yeah, these trucks are built for commercial duty, but lets not fool ourselves - thousands of people are driving these as personal vehicles.
I'm not just going to label drivers of commercial vehicles as knuckleheads who don't care about the way they drive a vehicle - tons of people drive their own cars into the ground, too. The manufacturers realize this. All my other vehicles respond normally in very cold weather, and don't seem to be too much worse for the wear as a result.
Then your only option is to take to dealer and have them hook up the CPU to see if your truck is up to spec. As far as safe, I came from a EB that would shut down on you in the rain/humid conditions leaving you w/o power and a truck that bucked like all the plugs fouled and FORD doesn't have a fix for that. Have dealer check it out maybe there is a issue they can correct with a reprogram. Seems today that our trucks are computer fixes not part fixes..
Doesn't matter which car company you buy a car from, problems can certainly arise. I just prefer Fords as far as trucks go.
I might mention it to the dealer, but they'll tell me to leave it overnight so its good and cold the next morning; they'll test drive it, and say everything performs to spec. Waste of time.
It does seem top work well, but it won't start my truck about 120 feet away from my office through steel walls - it is not a direct line of sight, however. Works great from inside my house, though.
#29
#30
