Dangerously slow pulling out in front of traffic - Page 2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 03-18-2014, 09:26 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty SoYouCanSuperDuty is offline
SoYouCanSuperDuty is starting off with a positive reputation.
I noticed my 6.2L F250 doesn't want to leave 1st gear when it's really cold. Gotta go to manual if I want to shift before it warms up. Still love her though.
Old 03-18-2014, 09:40 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
If its a matter of only a few minutes of warm up time to safely pull out into traffic why wouldn't you warm it up instead of playing Russian roulette every day. I understand the frustration but I definitely want you and everyone else to be safe.
Old 03-18-2014, 09:52 PM
2014 f250 2014 f250 is offline
2014 f250 is starting off with a positive reputation.
I haven'nt felt the hesitation on mine,but I have the remote start and have found that I really like it
Old 03-19-2014, 03:08 AM
Evil Elf Evil Elf is offline
Evil Elf is starting off with a positive reputation.
Had the same issue on mine, seems the only way to fix it at this time is a programmer.
The first week i had the truck I pulled out into traffic and it went dog slow then gassed it and the traction control kicked in. It just feels like you have very little control over your vehicle. Also noticed if you are cruising at about 40 and need to get between cars it takes about 3 seconds for the truck to down shift and think about doing something, by that time you lost your opportunity. At least in my old 2005 diesel you had turbo lag but then you had full power, do miss the extra torque though.
Old 03-19-2014, 07:24 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
You could try turning right, and going down to the next corner instead?
Even if you had "full power", turning left across a busy, multi-lane, fast traffic street is a "safety issue". Three right turns is safer than one left.
Old 03-19-2014, 09:07 AM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Quote:
Originally Posted by mfountain View Post
When started cold, my truck refuses to accelerate normally no matter how much throttle I give it. There's no miss or roughness at all. It just doesn't respond to additional throttle input. When it does this, it takes about a quarter mile to reach 45 - 50 mph. By the time I reach a stop sign about a mile from my driveway it will accelerate fine. It did it again this morning when it was about 10 degrees out.
Luckily for me, I live in the country and when I leave work the truck is starting to warm up by the time I reach a main highway.
BTW,,,,I traded my 2003 7.3 F250 XLT SWB EXT in on this truck in December 13 and have haven't looked back.
2011 F350 XLT EXT CAB SWB 4X4, 6.2L, 3.73
Maybe this cold start acceleration was programmed on purpose, we forget that these trucks were built for construction/fleet use. They know many of these trucks get driven by knuckleheads who don't give a rip about the truck warming up because its not there truck. To make these truck engines last they set a throttle response low to prevent any damage until hotter operating temps are achieved, either thru fluids/tranny. Then truck frees up. I haven't had any issues but I also let my truck thru remote start warm up to a minimum 50 degrees tranny temp before pulling out, by then the fluid engine temp is also up..So maybe just give truck time to warm up. Curious to see if these issues disappear in summer when trucks block/tranny hold temps overnight..
Old 03-19-2014, 09:36 AM
troverman's Avatar
troverman troverman is offline
troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.
I'd be surprised to learn if Ford programmed this sluggish response. It is unsafe from the standpoint that a driver becomes accustomed to the normal response of his/her vehicle. If I make a judgement to pull out into traffic because I am confident I can get out of the way, and then my truck does not perform the way it otherwise consistently does, I could end up in a serious accident. Yeah, these trucks are built for commercial duty, but lets not fool ourselves - thousands of people are driving these as personal vehicles.
I'm not just going to label drivers of commercial vehicles as knuckleheads who don't care about the way they drive a vehicle - tons of people drive their own cars into the ground, too. The manufacturers realize this. All my other vehicles respond normally in very cold weather, and don't seem to be too much worse for the wear as a result.
Old 03-19-2014, 10:07 AM
Then your only option is to take to dealer and have them hook up the CPU to see if your truck is up to spec. As far as safe, I came from a EB that would shut down on you in the rain/humid conditions leaving you w/o power and a truck that bucked like all the plugs fouled and FORD doesn't have a fix for that. Have dealer check it out maybe there is a issue they can correct with a reprogram. Seems today that our trucks are computer fixes not part fixes..
Old 03-19-2014, 10:55 AM
troverman's Avatar
Doesn't matter which car company you buy a car from, problems can certainly arise. I just prefer Fords as far as trucks go.
I might mention it to the dealer, but they'll tell me to leave it overnight so its good and cold the next morning; they'll test drive it, and say everything performs to spec. Waste of time.
Old 03-19-2014, 07:19 PM
Bmcush Bmcush is offline
Bmcush is starting off with a positive reputation.
As a side note about remote start I've been extremily impressed on how well it works. I essentially work in an above ground concrete bunker at an Air Force base. From inside my office I can it remote start and my 2014 fires right up from 80 yards away, amazing stuff.
Old 03-20-2014, 10:08 AM
troverman's Avatar
Quote:
It does seem top work well, but it won't start my truck about 120 feet away from my office through steel walls - it is not a direct line of sight, however. Works great from inside my house, though.
Old 03-20-2014, 04:24 PM
bigjr2's Avatar
bigjr2 bigjr2 is offline
bigjr2 is starting off with a positive reputation.
I wonder if its something that can be programed from the dealer I know some vehicles can be set to different specs by the ford techs.
  #28
Old 03-20-2014, 08:14 PM
eberlestock's Avatar
eberlestock eberlestock is offline
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
A tuner fixes this up. Makes the truck respond like you think it should with 385 horse. I drove a new gm company truck the other day with a 5.3 in it. I think it has 315-325 horse. It feels much quicker up until top rpm.
  #29
Old 03-21-2014, 08:21 PM
saltbranch saltbranch is offline
saltbranch is starting off with a positive reputation.
My truck seems to respond fine, I have no problems merging with traffic in Houston.. Some times I wonder how fast a 8000 lbs. truck is expected to run? My only bitch is the speed limiter...When the warranty is up I will be getting it tuned.
  #30
Old 03-21-2014, 09:40 PM
djm1204's Avatar
djm1204 djm1204 is offline
djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.
Just curious - and I have nothing against speed - but exactly how much faster does anyone really need this brick to travel down the road ? It's a truck designed to work.
Any way to disable speed restrictor? maxtor 6.7L Power Stroke Diesel 21 09-17-2016 01:58 AM
Overheated auto trans southtexasidi 1987 - 1996 F150 & Larger F-Series Trucks 5 10-02-2015 11:39 AM
Traction-Lok Equipped??? MK2Pierce Excursion - King of SUVs 9 12-13-2014 11:06 AM
O/D light flashes, tranny shifts funny, then v10 dies...?? 12valveEx Excursion - King of SUVs 48 11-03-2014 01:16 PM
help! stalling/poor idle 87ford 1987 - 1996 F150 & Larger F-Series Trucks 14 10-20-2006 04:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
