Play in timing chain - 460
Hi all,
I was puting my oil pan back on last night and saw the timing chain up in there. For the heck of it, I pushed on the chain between the gears to check for play (like checking a fan belt). There's a lot! It feel really loose.
Is it supposed to be like that? Should it have any play or should it be tight?
Thanks in advance!
Kevin K.
Thanks in advance!
Kevin K.
I don't have my shop manuals with me at work, but I think there should only be about 1/4" slack in there. I once got a '76 Cougar w/460 for free because "it won't start". I cranked on it to confirm there was fuel and spark, and sure enough it wouldn't stay running. The chain was so loose that I could see the irregularities with the timing light!
I hauled it off and put its engine in my first '76 van for more than 5 years! (With suitable mods of course... )
Regarding 385 timing sets FYI. . .
When R&Ring timing sets on 385 engine, get/ use timing set for 68-72 engine. I prefer Cloyes Accu Roll sets my self, however it's no matter if you use roller, or conventional timing set to resolve the following, built in "problem".
In 73 FoMoCo built a retard condition into 385's to deal with EGR issues in traffic & Granny usage. It is about a degree & 1/2 late to crank when 73 & up timing sets are correctly installed w/ marks aligned "dead on". If you drive to church often and cruise heavy traffic a lot, you may need this. BUT. . . If you drive normally you don't want it.
Use earlier timing set & engine will be 0* @ TDC,as it is should be to run right, [US Govt not withstanding of course]. I did D6VE w/ flat top pistons 4 guy as I just explained. I got him to use Blue Stripe module & breakerless ign system also. With the changes & dual, 2 1/4" exhaust, all the way back, good performance @ 12- 14 mpg, became great performance @ 17+mpg [once he learned to keep his foot out of it instead of constantly hammering it cause it was neat]
Thought you'd want to look into this bit of information on 385s. FBp
It started in 73 with the D3VE engines, it maybe 4 deg at the crank because the crank is running 2:1 to the cam, right?
All I know is if you P&G the cylinders using good degree wheel zero on the cam & zero on the crank don't happen at TDC like it does with a 72 & earlier 385s.
Also I believe compression ratios were dropping from the DOVEs onward. But Doves were 67=68=69 & 70 although I've run across a few D1VEs with 9.75:1. All the D2VEs have been 9.5:1 with OEM heads & pistons. But "change" was a result of 1972 fuel crisis & US EPA mandates which were effective in 1973.
Point is get a timing set for a 68 -70 & run better than if you use one for a 73 & up. Didn't know how common this knowledge was.
Glad to see y'all are ahead of the curve on it tho!
Mil1ion, you're correct. C8 (1968), C9 (1969) then DO were used in '70&71 with 78cc combustion chambers. Rail rockers were used from '68-71 and switched to pedestal mounted (excepting the PI) in '72. The standard production '72 was an 8.5:1 c/r cam timing retarded engine with D2 open chamber heads of 89cc. In '73 the compression was dropped again to 8.0:1 with 96cc+ combustion chambers. '71 was the last year for high compression, straight-up cam timing 385s.
I replaced the chain and gears in my 429 with a Wolverine true roller. After 3 years of use it is still as tight as the day I installed it. I had to remove it a while back and I had to work the chain and gears together about 1/32" at a time until it cleared the end of the cam. At the very least I install double roller sets when I replace a timing set now.
Mil1ion & georgedavila
You guys are right & I wrote that wrong. While I was typing it I was thinking the 68 - 70 all had the same style heads & pistons etc. In that way they all resemble the DOVE.
And yes I know D= the decade [70's] + 0 = the year in the deacde zero or 1970 itself. . . .it's just hurried up sloppyness on my part & I apologize & stand corected, thanx!
Also it's a treat to have folks who know what they are talking about get on my case for a change! I'm ragged by the "Orange Replacement Engine" crowd usually. Y'all know how that can go, right?
THANX again for pointing out my error, and FWIW at least I thought I knew what I meant.
Aaron-71
02-23-2011 01:06 PM
stewart
07-27-2009 12:14 PM
TxBrokenarrow
05-10-2005 04:59 PM
ExplicitHP
02-04-2002 05:18 PM
