cab corners/inner cab corners
Hello I just bought a 1987 Ford F-250 supercab 6.9 ive been reading on these forums since then and have got a lot of help with issues since but as of right now im wondering about the cab corners both side are gone left side is worse I cut it out and the bottom and back part is rusted also and I want to replace it all just don't know how never done body work ive found the cab corners but don't know about the inner and bottom part any help thanks
Who has the super cab corners? I thought only reg cab corners where out there, that's good to know. I'm doing the outer skin on one of mine and just cut some good metal from a donor.
The inner bracing is pretty simple and you could just hand bend some pieces, it doesn't have to be pretty. My inner is intact and it's opened up now, I can get you a pic if it helps.
That looks all too familiar.
https://www.ford-trucks.com/forums/1...l#post14041623
I ended up making my own patch panels from sheetmetal I harvested from the rusty bed that I was replacing at the same time, though places like Bronco Graveyard and LMC carry replacement patch panels. If you've never used a welder before, I'd suggest a fair amount of practice using the same gauge sheetmetal you'll be welding before attempting to weld in your new panels.
Yeah that's what ive been told I'd like tp replace my bed also its not in the worst shape but it will need some work both rear bottom corners on it were crushed at some point and some of the cargo holes are broke a friend gave a idea of fiberglassing the cab corners since im not looking for a show truck just want something solid
Had the same problem, paint bubbled up little rust figured it was the skin until got into it, damaged extended well beyond it.
Looked like this once skin was removed,
copied damaged section, two pieces bent then weld to each other make up the part. (laying on ground "top" side down)
Piece bent as needed recreate the inner wall first (stickers on it in image)
Then bottom channel recreated in second image added in with the inner wall (what would be the center wall, inner wall inside cab) section repaired with new metal cut bent welded in place.
that was all coated with etching primer then plastic roof cement over that before outer repair panel welded in place,
Seam hidden behind body side molding, didn't need to be as its undetectable but appeared to be the appropriate location for it, the repair panel itself was much taller than that though. Repair panel ya get is a fairly large piece up just beyond body line, full wrap around at rear and extends into door jamb.
I started by removing the rear interior of the truck, back seat, trim, carpet etc etc, then sand blasting all rust away before adding new metal.
Have more complete set of pictures but didn't want to overload the board/thread, hope gives you more to go on as sounds like its damage is equal that of yours.
As far as access to it after the fact no I really didn't need to, coated everything before closing it up real good including the back side of repair panel itself.
Even though it's no longer driven, hasn't seen a salt covered road in years, I did quite a bit of work on it to prevent rust anyway, no way to get in its all sealed up underneath/everywhere.
Yea best bet remove the box get it out of the way but be sure any metal work done will still line up to it. I took careful measurements from the frame etc after removing the box and before cutting the corner out, did so so I knew where the replacement metal should land and line up to it once it was bolted back on.
Yep.
