Lowering options for 80-86 F100
Old 12-10-2010, 02:21 PM
LOWFOMOCO's Avatar
LOWFOMOCO
LOWFOMOCO is offline
Help...
I have an 80 F100 with dropped I-Beams and I am not satisfied. I was wondering if anbody on here has used the FatMan Mustang II kit or Jag. I am ready to pull the beams and do something else. Has anybody sub-framed an 80-86? If so what did you use. I want the truck to sit lower than it is now and I want it to ride good as well. I am not interested in air bags but I want it as low as I can get it. I plan on leaving the original 6 cylinder and 4 speed in it.
Any help or Info would be greatly appreciated.
I know some of you purist may think I am a fool but to each his own right?
Here is a pic as it sits now.
Old 12-10-2010, 03:21 PM
parr4's Avatar
parr4
parr4 is offline
Looks great to me
Old 12-10-2010, 04:04 PM
BikeMaker's Avatar
BikeMaker
BikeMaker is offline
I used to have one that sat just about the same, and I wanted it even lower, but there's no easy way that I found to do it. Either welding a new subframe on like you mentioned or channeling the body down over the frame are probably the only options.
Old 12-10-2010, 04:54 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
Old 12-13-2010, 01:29 PM
LOWFOMOCO's Avatar
LOWFOMOCO
I actually saw this done and was excited about the options....however the frame is a few inches wider on my truck so it would have to be heavily modified.
Has anyone on here used the Mustang II kit from FatMan? I really don't want to fork out that kind of money but it looks like a great solution.
Old 12-14-2010, 09:17 AM
LOWFOMOCO's Avatar
LOWFOMOCO
I saw this truck at a local show....it had a Mustang II front end under it..I talked to the owner and he said it was heavily modified in order to get the big block in it...
The following users liked this post:
Old 01-03-2011, 11:28 PM
cliffordingles's Avatar
cliffordingles
cliffordingles is offline
Old 03-27-2014, 11:38 PM
crestfallinman's Avatar
crestfallinman
crestfallinman is offline
i know this is a super old thread that im reviving, but have you checked out coil spring specialties? they make custom springs i got a set made 1.5" lowered and 15% stiffer and it rides like a dream
droppedf100
WTB - Parts & other
02-20-2018 07:18 PM
Montync
WTB - Parts & other
08-03-2017 04:10 PM
cadunkle
04-22-2017 07:40 PM
droppedf100
Ford Truck Parts for Sale
09-23-2016 10:55 PM
MUSKRATT2
06-10-2012 06:52 PM
Quick Reply: Lowering options for 80-86 F100
