John Mummert Ram Horn Installation Bolt
Old 03-15-2014, 08:45 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Im installing a pair of John Mummert Ram Horns on my Y block. The previous owners had the stock manifolds held on with what ever nuts they cound find. Is there a correct length nut that will work in all mount holes on both sides? Grade 5 or 8?
Old 03-17-2014, 08:00 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
A lot of orig parts were fastened on with a special length bolt, and are hard to find now.Measure the depth of the hole, + the thickness of the manifold, if the bolts are longer, cut them off enough so they don't bottom out.
Old 03-17-2014, 08:13 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
No why didnt I think of that, lol. Thanks for your response.
Old 03-21-2014, 02:55 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Easiest way is to stick the bolt/s in with the manifolds off. I counted 5 threads past the base and cut them. Also, the word at Yblocks forever is DO NOT use manifold to head gaskets. You run the risk of cracking them. I checked the book and sho'nuff, it says to use graphite grease. I'm gonna use some high temp anti sneeze
Old 03-21-2014, 07:46 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Will do, Im going to use the high temp anti sieze too. I guess not the copper stuff though. Thanks!
Old 03-21-2014, 08:59 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Old 03-21-2014, 09:13 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Great, Ill order some of that too. Thanks for letting me know!
Fefanatic
6.4L Power Stroke Diesel
04-03-2019 11:36 AM
BenS77
08-07-2013 11:50 PM
dyoungen
06-17-2012 06:40 PM
hoffmmd
03-07-2007 08:40 AM
ejpreston
1983 - 2012 Ranger & B-Series
04-06-2004 05:33 PM
Quick Reply: John Mummert Ram Horn Installation Bolt
