Best route for Headliner
For a '48 you should also check with Classic Haulers.
Search - Classic Haulers F-1 Parts
Raytasch had a post here the other day saying Dennis Carpenter had a special on oversize flat rate shipping; also if you go out on fleabay he sells the headliners there and shipping is the same $14.95 for the 48-52 which includes the eight piece kit; kick panels, side panels & below window. 56 headliner only shipping is $9.95. I'm thinking about ordering one this week.
That is the headliner that I used and it fit very well. I recommend it. I covered it with headliner material. I did drill the headliner and cab to install blind offset fasteners about every 6 inches over the doors. I did not use the 2 pieces either side of the rear window since I made a panel that goes from the floor (and around the gas tank) to the lower edge of the larger piece in the photo. That panel is covered with the interior fabric that I bought for that area and the upper area of the door panels. I have not done the door panels yet.
Boy that looks good. I like the two tone seats especially how the center of the seat carried over to the visors and doors.
Does it use the same retainer rubber and clips?
headliner
In my 56 I used the ABS from Mid Fifty. I picked it up at the F100 Mationals to save shipping. The fit was very good and I only had to trim at the back window(its a big back window). I then painted it with gray SMS paint. Fit is still very good, I even found sheets of ABS panel board and made my own kick panels, One hint make sure you fit them in hot weather, they will shrink in winter and expand in the spring, much like vinyl siding.
#28
It is a very straight forward install and fit is great. It is a tight fit though so it takes some patience to move it into it's home. I did it twice, once to mock it up and trim the dome light holes, then I pulled it out to upholster and re-install. Second time was a breeze.
#29
Headliner installation
I also got my headliner at Sac. Vintage Ford in a kit with the other back-of -cab covers. All of it fit quite well. The only issue I had was pushing the headliner in too far above the windshield which left a gap above the back window which I then had to reposition the headliner. I would advise putting in the covers at the back of the cab around the rear window first and then the headliner. Also spraying the back of the pieces that are to be curved with a solution of 80% household ammonia and 20% water will greatly aid in the bending. Just moistened , not soaked.
Good luck with whatever you choose.
#30
Im987: I am assuming that when you mention the rubber channel at the windshield and the water/ ammonia mix you are referring to the installation of a hardboard liner. I see that on my cab (currently with no headliner) there are two holes in the sheet metal headliner support at the cab ceiling for a couple of screws. Was there any problem locating these screw locations after the headliner was in? You mention it being loose enough in the rubber channel so that it can move back and forth a bit.
