Ok, I must be really dumb... tail lights
Low voltage
Check the voltage that leaves the brake switch to a "good" ground. It should be 12 volts. If it isn't then soemthing is dropping the voltage (bad connection) on switch ?
If the voltage is good leaving switch, go to the wire at the light, without light connected is the voltage 12 volts , making sure you have a good ground connection on the meter. If it is then your light is not making good ground. If not you have a short or grounded wire from switch.
You have to have a good ground reference when measuring the voltage.
Hope this helps
Tom
Hope this helps
Tom
Steve49841
04-07-2015 05:38 PM
