1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
VIN Help, axle and springs
Old 03-15-2014, 03:15 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Hey everybody, would like some idea what axle is installed if possible from the VIN. It has two sets of leaves in the back. Was that factory? Rides like a logging truck without some weight in back.
Edit. See that I posted this in the unibody forum, that nobody ever reads. Oh well.
Old 03-31-2014, 02:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
F10 = F100 2WD
C = 292 2V
K = Kansas City MO Assembly Plant.
558537 = 1964, assembled June 1964 (it's not a Uni).
128" Wheelbase.
V = Academy Blue.
F100 2WD, 5,000 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Rib Vinyl // 81 = 81A Standard Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from.
1964 F100 2WD could have a 5 leaf spring pack w/a 950 lb. load rate or a 6 leaf spring pack w/a 1250 lb. load rate. An auxillary spring (1 leaf) was optional for both.
The rear springs are the same 1957/67 F100 2WD, so there are other leaf spring packs that could be used.
Murphy1966
10-30-2018 11:04 AM
mhu
05-11-2015 03:14 AM
Tedster9
03-16-2014 07:52 AM
Crash'n'Burn
10-17-2013 09:37 PM
cheddar89
03-08-2012 09:13 AM
Quick Reply: VIN Help, axle and springs
