Sporadic ticking in gear
Hi All!
This place has been a great help in starting to troubleshoot problems, so I thought I'd share this one with you.
77 F250 400
Truck has been running fine, but now I notice when I put it in gear or am driving I sometimes here a fast ticking or clicking - almost like it is reving up just a little bit for a second.
I recorded the sound:
http://automaticrabbit.com/things/truck.m4a
The first bit is it just idling, then you can hear me put it into gear. Shortly after that you can hear this jumpy clicking a few times at 22sec and 24 sec, 27 sec and more.
Any hints on where I should start?
Thanks!
-Todd
77 F250 400
Thanks!
-Todd
My guess is something in the transmission, I've never heard of a torque converter making that sound before.
Might post in the Transmission forum and see if one of the knowledgeable folks stops by and sees it.
Clutch, Transmission, Differential, Axle & Transfer Case - Ford Truck Enthusiasts Forums
Update
Hi All!
I thought I'd provide an update.
First, thanks for the responses! They definitely gave me a good starting point. I had just had the transmission rebuilt, so I did swing by and talk to those guys. He didn't seem to think it was tranny related, so I went down the misfire route.
I decided to put in new plugs, wires and cap - turns out that inside the cap there was a bad connection. Seems like it would sort of work sometimes, but not too well for one cylinder. It was corroded and charred. After that little tune up, things are back to normal!
Thanks again, I really appreciate it!!
-Todd
-Todd
Tugly
20
09-23-2015 02:08 PM
woodtrucker
10-04-2013 11:09 AM
