1993 5.0 engine vs 1986 5.0 engine
on
Your '85 motor has low compression smog heads and a small flat tappet cam while the '93 has higher compression heads and a roller cam so yeah the '93 is better. However...
The absolute best motor you could get would be a 96-97.5 Explorer 5.0 since it has even better heads(GT40) and a larger roller cam, and the next best option is a '94+ truck motor because it has the same roller cam as the Explorer motor. These '94+ motor have a different firing order than your '85 but that doesn't matter as far as the EFI system is concerned since it fires injectors in batches and the resulting overlap works with both firing orders.
on
Nope sorry... the truck motors didn't get a roller cam until 1992 and even then it was the tiny little thing from the 150hp crown vic motor. And mass air didn't happen until 1995 50-state and Canada with Cali getting it a year earlier.
Thanks for clearing that up. I have built a lot of 5.0 mustangs over the years and didn't realize there were that many differences between it and the truck engines.
skid pan
05-15-2010 08:02 PM
Supercab
11-12-2008 08:54 PM
