Need advice: Flexplate Ring Gear & Starter
Automatic, new NAPA 3-bolt starter replaced dead, possibly original starter.
Got several successful starts, today, not.
Cranked about 4 times, grrrr-spinnnnnnnnn! each time. Put on charger before last try, so it's not low batteries failing to engage the Bendix.
Pulled starter and inspection cover. Starter pinion teeth look untouched. Ring gear has three damaged teeth where the pinion was grinding. Lost about 1/8" off the engine side of the center tooth, less on either side. I didn't see any "old" metal in the bottom of the inspection cover, so I'm guessing all damage is from this start attempt, and possibly due to a weak or badly-timed Bendix on the new starter. Starter is getting replaced one way or the other.
So here's my question: Do I also replace the flexplate & ring gear and , (shop will do it, not me...), or just the starter, and figure I won't have any problems even if the start is on those three teeth?
If those teeth are problems, then I'll miss about 1 out of every 56 tries (3/168), and the odds will get worse as adjacent teeth get worn by missed starts. I don't want to be crawling under the truck in sloping mud or briers, pulling the inspection cover, and prying the flywheel over.
Received 3,090 Likes
on
grayson20
09-23-2016 10:22 AM
bremen242
08-24-2004 03:41 PM
