Electrical connection suggestions
Since I'm using a one piece fiberglass front end on my build, I'm looking for suggestions for quick disconnect at the front of my frame where the wires for hi/lo headlight, signal and parking lights head out to their new home. I want to be able to unplug the light harness and take the front end off easily. My particular wiring kit has four wires going to the left headlight location and four separate wires going to the right headlight location. I've done some looking for a quick disconnect that will accommodate 8 wires but so far.........nothing.
Headlight hi/lo wires-14 gauge, park, signal-16 gauge.
The last flip front end that I did was on a Henry J and I used individual connectors for each wire. Worked ok, but didn't look great and was a pain when I removed the front end.
I think that is an excellent idea, especially if you have a one-piece front end. Would this work?
Earmark, Inc. :: MARINE :: Accessories :: Connectors, Terminals & Wiring Accessories :: 8-Pin Flat Quick-Disconnect Connector Set
Earmark, Inc.*::*MARINE*::*Accessories*::*Connectors, Terminals & Wiring Accessories*::*8-Pin Flat Quick-Disconnect Connector Set
Drew,
I'm facing the same issue on my truck. I just pulled the front clip and cut my harness with plans of wiring in some weatherproof connectors.
I like the Packard style weatherproof connectors like whats found under the hood of GM cars. You can get the connectors kits that accommodate from 1 to 6 wires. Similar to this;
Somewhere recently through Amazon I found a company selling kits of three connectors in either the 3 wire, 4 wire or 6 wire configurations.
My harness exits my cab near the passenger side footboard. That's where I'll put my connectors.
Bobby
Bobby
Drew,
Amazon.com: Delphi Packard Weatherpack 3 Pin Terminal Kit 12 AWG: Automotive
Bobby
Bobby
Bobby, that looks promising. Being weatherproof is an added plus since my connection would be right at the front of the frame. Guess I need to educate myself about how these are assembled.
Thanks, you've thrown some very helpful suggestions my way since I've been on this site. Much appreciated.
the weather proofing is a great idea, that connector is easy to build, i would recommend soldering the wires in addition to crimping them. and then get a can of liquid electrical tape and seal the area where the wires enter the back of the connector. I could point you to a bunch of techie sites that have connectors but sad to say amazon would be the easiest and its a good price.
Source: I'm a nerd
Source: I'm a nerd
Drew,
Those Packard type weatherproof connectors do take a special crimper (its not very expensive) the terminal ends have 3 separate areas that take crimping; the first section crimps onto the bare wire, the 2nd section crimps onto the insulation, and the final section crimps onto the silicone weatherproof gasket doohickey. When the terminals are inserted into the connector they lock into place (special tools to release them from the connector...also inexpensive)
Ford (well, all manfactureres) use some form of weatherproof connectors for their EFI wiring under the hoods. I'm just he most familiar with the GM style and like them best. It seems like the GM connectors are easy to disconnect and reconnect while the Ford style seems to break the locking tabs when you disconnect them.
Bobby
Bobby
Drew,
Bobby
Bobby
I found a lot to look at but came up short on what I wanted. I'll continue looking at the marine products to see what else I find. I never could find Doraville's information about connectors.
Dang, I didn't realize they wanted so much for those crimpers.....anywhere from $80 t0 $100....sheesh.
I have a set of crimpers. I'd gladly let you borrow them if you like. I can't imaging shipping would be too horrible between NM and TN.
I wonder if one of the local parts houses has a set to borrow. Or, do you have a buddy at a GM dealership that you could borrow them from? If not, let me know, we can work out some kind of borrow thing.
Bobby
electrical disconnects
I am wiring my dash and wanted to be able to unplug it easily I bought weatherpak connectors from Sherco Auto & Marine in Ft Lauderdale, Fl
I bought 1 each 4-5-& 6 plug connectors both male & female the cost was around $2.00 each and the terminal were around $2.75 a bag of 10
Their website is
https://www.sherco-auto.com/
They are close to my house and I use them a lot got my wire looms, & steel brake lines in 25' rolls there
Their website is
Drew,
Bobby
Bobby
I'm tempted to visit my local salvage yard and nose around under the hood of some GM vehicles to see what kind of plugs have been used.
Their website is
Their website is
Let me know. If need be we can ship it back and forth. It wouldn't take much to slip it in a padded envelop.
Bobby
cwpowell
03-11-2010 06:56 AM
sancochojoe
02-24-2004 01:59 PM
blaster999
10-23-2003 10:15 PM
